FREEBIES!
TJExcalibur
Out of this world.
Southern England
1- CM 1.2 with arms, lnb holder, feedhorn.
2- Another feedhorn.
3- CM 1M with arms and lnb holder.
4. Primesat wall mount no pole.
Some shown in pic below. Backplate is for the 1m dish.
All OK, just grubby. Bournemouth collection or arrange carrier. Can post the smaller items.
Postage at cost, free packing, a donation to forum if you can afford it.
Wow...
I am verrry interested in the white metal LNB holder in the picture and the feedhorn (though more the holder). I can do swapsies with my holder with feedhorn adapter, which is plastic, so that you're not left without a holder for one of the dishes?
TJExcalibur
Out of this world.
Southern England
Wow...
No problem. PM me your address and I will post.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
TJExcalibur, would you be so kind as to provide the postage costs and/or weight of each item, I think I would be interested in a lot of the items :)
TJExcalibur
Out of this world.
Southern England
The lnb holder has gone, done a swap. Unable to give quotes for the 2 dishes and wall mount because it depends where you live. I would prefer it if you obtained your own quotes from a carrier of your choice. I have used Shiply before, found them good and they do not require packing for large items.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I believe I need to supply weight and dimensions in order to obtain a quote, so most probably the pickup postcode, if you wouldn't my PMing me if you don't want to put in the thread, I don't mind obtaining my own quotes :)
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
i wouldnt mind a feedhorn for my dish if there is one going still. i will of course re-imburse the costs to you via BT, ill take wall mount if still available. see what satalite wants first as he asked first
TJExcalibur
Out of this world.
Southern England
Good, less for the tip.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Regarding the dishes, would I need a polar mount for the 1.2? and a pole for the 1.0?
Noob questions sorry.
If so how much would a polar mount / poles set me back?
archive10
I'd take the lot, except it's currently too far for a reasonable pick-up. 8-(
I saw this post from TJ when there were only three views and no replies. I was soooooo tempted to ask for the CM1.2 kit but reality dragged me back and I kept stumm.
We can but dream...
Same here (although I do have an exgf down near Salisbury Id love to find a reason to visit again ;)
TJExcalibur
Out of this world.
Southern England
Still to go if wanted.
CM 1.2 with arms, lnb holder.
CM 1M with arms and lnb holder and back plate.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I have found that the best postage cost i could find would be about £35 per dish. Just wanted to definitively find out the mount costs.
I'm assuming £35 is worth it for a quality dish?
TJExcalibur
Out of this world.
Southern England
Only the 2 dishes left. I was unsure if you wanted the mount, depending on your setup. £35 well worth it when you think of the original cost.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
No problem on the wall mount, I don't currently have any setup, but don't envisage putting a dish on any walls.
I wont be able to use a dish straight away as I don't live in a property with line of site from the back yard. It's for the future.
Price I got was from Parcel force, so don't know if they require the dishes to have packaging? Im thinking just the 1.0m will be enough for me :)
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
On the other hand il always be thinking about both dishes, might be cheaper to package them together?
I did a rough guess of the weight for the 1.2 @ 20kg, does this sound about right?
If the 1.2m CM bits are still left at the end it's JUST possible I could divert on my way back through the UK at the end of the month. I'd have to prepare the way with SWMBO veeeeery carefully on this though.
TJExcalibur
Out of this world.
Southern England
33.5 kg according to the satellitesuperstore
