Tururu
Assembled with recycled parts
Recycled as the owner.
Some changes channels, ok this morning and this afternoon about 19:00 UTC (6-Aug8-2015).
Algunos cambios de canales, esta mañana ok y esta tarde sobre las 19:00 UTC.(6-Agosto-2015)
Borrado/Delete ITV+1 SID-10021 10832 H 22000 Astra2E
Borrado/Delete ITV HD SID-21010 11097 V 23000 Astra2G
Borrado/Delete ITV Wales SID-10020 10832 H 22000 Astra2E
Actualizar/Update 12155 ==> ITV+1 10993 H 22000 Astra2G
Actualizar/Update 12150 ==> ITV Wales 10993 H 22000 Astra2G
Añadido/Add 53589 11387 H 27500 Astra2E
PD:Buena pesca/Good fishing.
Tururu
Continue to change, making gigs night from 12 to 13 August 2015.
In 28'2ºEste.
TSID updated on 18 channels, cause.?
The TSID-2073 pass the TSID-2065
Erasing 2 channels.
Star Life OK.- 11343 V 27500 SID-55210 TSID-2304
AAJ TAK .....- 11343 V 27500 SID-55216 TSID-2304
Changing label/name 2 channels
52185/BSkyB ==> Star Life OK.- 11264 H 27500 SID-52185 TSID-2301, Astra2G UK ==> Europe
54165/BSkyB ==> AAJ TAK .,,,,- 11567 V 22000 SID-54165 TSID-2076, Astra2G UK ==> Europe
Tururu
More changes, 16-17 August 2015.
TSID continue the change, deleted 42, 40 and a channel changed rename / tag
TSID 2301 ====> TSID 2107
TSID 2311 ====> TSID 2105
Deleted channel True Ent+1 with TSID 2314
Chat Box ====> TSID 2316.
Mas cambios, 16-17 Agosto del 2015.
Continuan los cambio de TSID, borrados 42, cambiados 40 y un canal cambia de nombre / etiqueta
De TSID 2301 ====> TSID 2107
De TSID 2311 ====> TSID 2105
Borran canal True Ent+1 con TSID 2314
Tururu
08.18.2015 2:30
14 more changing channels TSID
TSID 2304 ==> TSID 2112
1 channel updated name/label 50315 ==> AMC from BT
Tururu
18-8-2015 17:00
More changing channels TSID.
Added 86 channels
Deleted 85 channels
Delete channel TSID 2075 ==>add channel TSID 2095
Delete channel TSID 2076 ==>add channel TSID 2096
Delete channel TSID 2411 ==>add channel TSID 2103
Delete channel TSID 2412 ==>addchannel TSID 2104
1 Channel add 52520 to TSID 2306
Tururu
More changes, 20 August 2015, 11:00
TSID continue the change, 43 services deleted, 47 services added.
TSID 2407 ====> TSID 2097
TSID 2306 ====> TSID 2116
TSID 2074 ====> TSID 2067
TSID 2036 ====> TSID 2059
Tururu
More changes, 20 August 2015, 19:30
TSID continue the change, 33 services deleted, 30 services added, 2 services update.
TSID 2314 ====> TSID 2110
TSID 2303 ====> TSID 2109
ITV HD Delete.
Tururu
Changes from 1 to 21 August 2015.
Cambios del 1 al 21 de agosto del 2015.
237 services deleted (TSID).
237 services added (TSID).
ITV HD en 11097 V 23000 2/3, sorry/apenado. :-lol
Continue to issue the 3 channels with SID 21000, 21020 and 21030.
Continuan emitiendo los 3 canales con SID 21000, 21020 y 21030.
Tururu
More changes, 08.24.2015, 11:45 (GMT)
2 services update.
TV SHOP =======> GR SHOP
Sky Greats HD====> SKy Greats HD
PS:Notice to technicians, we have differences k of K is important (new rule).:-rofl2
PD:Aviso para los tecnicos, tenemos que diferencias K de k, es importante (nueva norma).
Tururu
More changes, 26 August 2015, 18:50
TSID continue the change, 16 services deleted, 13 services added, 7 servicenames updated.
TSID 2015 ====> TSID 2093
TSID 2095 ====> TSID 2116
SID 13598 ====> SID 53598
SID 9359 ====> SID 53591
Add 53545
Update SKy Greats HD ==> Sky Greats HD (K => k).
geoffrey
Zichron Yaacov
2.4M ChannelMaster Offset with Smart Titanium TQS LNB. LG SMART TV with SuperTrack V-Box 2 on ChannelMaster 1.2M Offset. TBS5925 tuner with EBSPro on Windows 10 laptop. Satlook Digital NIT.
Israel
11200h low power of me becon now
Solly
Have you been able to lock the CNN transponder on 11112H at your location?
I have been unable so far to lock anything on 2G in Zichron Yaacov but on my Satlook the 11112H transponder looked to be possible.
I am using the published settings of 22000-5/6 and have had the best looking signal on a Satlook Analyser using a single polarity horizontal feed and LNB on my 2.4m ChannelMaster dish.
geoffrey
Zichron Yaacov
Israel
Solly
Maybe I did not myself clear.
Even with the signal looking OK I was unable to lock 11112H.
Are you able to lock 11112H?
Tururu
If you can set the meter in dB (C / N), so you'll have a better idea whether the tuner and you have what can lock/tune.
Normally they tuners usually give the signal levels/SNR, quality/AGC and dB, if you know the limits of the tuner, you know if it is possible or not.
As a reference for comparison, the satellite AzerSpace1/Africasat1a to 46.0°East is out of reach with the antenna that I have (94cm) in the meter Rover SRM-50 depending on the tp, I have to 58.1dBμV to 61.5dBμV and the tuner is fully blind.
Since the meter in dB (I have pictures) of the order of 3'0dB if I remember correctly, The minimum DreamBox800S-HD is in 3.5dB.
Si puedes configurar el medidor en db (C/N), de esta manera tendras una idea mas aproximada y saber si el sintonizador que tienes lo puede bloquear/sintonizar.
Normalmente los sintonizadores suelen dar los niveles de señal/SNR, calidad/AGC y dB, si sabes el limite del sintonizador, puedes saber si es posible o no.
Como referencia para comparar, el satelite AzerSpace1/Africasat1a a 46.0°Este esta fuera de alcance con la antena que tengo (94cm), en el medidor Rover SRM-50 dependiendo del tp, tengo de 58.1dBµV a 61.5dBµV y el sintonizador esta completamente ciego.
Puesto el medidor en dB (no tengo fotos) del orden de 3'0dB si no recuerdo mal, el minimo de la DreamBox800S-HD esta en 3.5dB.
Some pictures of the spectrum analyzer and sees the tuner (for example).
Unas fotos del analizador de espectro y lo que ve el sintonizador (como ejemplo).
geoffrey
Zichron Yaacov
Israel
Tururu
Thanks for your response.
I should have added the S/N figure derived from the Satlook - it was 7.0db which according to Lyngsat's data should have locked the transponder (they say 6.5dB is enough). I enclose a screen shot:sn-of-11112h.jpg
Have you any idea what is the adjacent transponder at 11088H - its not on the Lyngsat list?
I have checked the Satlook on my 1.2m dish at 19E looking at the 11612H transponder.
This is supposed to need 6.5dB S/N to lock but actually was locked at an indicated 3.4dB on the Satlook.
See the enclosed two screen shots:
And has anyone else on the fringe been able to lock the Astra 2G CNN channel on 11112H ?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
'Fringe' here (Alicante) depends on dish sise but on 1.8m:-
geoffrey
Zichron Yaacov
Israel
mickwig
90cm Astra1 dish;
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Many thanks for that - but I still do not understand what is the peak on my spectrum at 11088H.
Is your list derived from the actual transmission?
Blind scan + RF scan (5 mins ago) ......good luck with your trials. :)
geoffrey
Zichron Yaacov
Israel
According to Flysat:
11082 H, DVB-S/MPEG-2 22000 5/6
Sky UK: AMC from BT - Motors TV UK - BT Sport Europe
BT Sport 1/2 - BT Sport / ESPN UK
BT Sport Extra 1 - BT Sport Mosaic
-w- Videoguard AMC from BT
encrypted now
Pavers Shoes TV 2319 2320 Eng 50313
Inspirational TV w 2315 2316 Eng 50390
Its on 2G Europe. Thats why all TP close are hard to get in the fringes.
But I can see from the spectrum analyser that the second peak is not 11082H. I had wondered whether I was on on the wrong satellite but nothing nearby seems to fit the bill.
Many thanks for the scan data - I must be picking up the 11088H peak from somewhere else as its way off from 11082H.
And maybe my 11112H peak is not coming from 2G?
Tururu
CNN 11111 H 22000 Madrid (Spain) breaks the level indicator and am not useful reference.
The minimum level depends on the tuner, in my case it is better VU + DUO2 I have the DB800S-HD, but familiarity and comfort for fishing is the equipment I use normally.
What say the web is one thing and reality is not always the same, apart from the environmental conditions that modify levels many times during testing.
Comment for those who are closer to UK and can tune its beam (UK:-rofl2), who may have changes soon, the reference is the tp 11053 H 23000, normally this interfered by tp's coming and I can not tune last night nothing and I can tune it perfectly today, the last time only lasted 24 hours, and make a picture with the tuner and sees the spectrum analyzer to compare with the old ones I have on other occasions.
Regardless of the possible interference ....
Eutelsat25B / Eshail1 at 25.5 ° East on 11046 H 27500 3/4 (verified now and before).
Badr6 at 26.0 ° Eeste in 10930H 27500 3/4 (as reference satellite.)
In the photos of the spectrum analyzer marcare tp 11082H (Beam Europe), the signal is very strong.
PS: The photos Analyzer tarry a while to download.
CNN en 11111 H 22000 por Madrid (España) rompe el indicador de nivel y no soy util de referencia.
Los niveles minimos depende del sintonizador, en mi caso es mejor el VU+DUO2 que tengo que la DB800S-HD, pero por familiaridad y comodidad para las pescas es el equipo que uso normalmente.
Lo que digan las web es una cosa y la realidad no siempre es igual, aparte de las condiciones medioambientales que modifican los niveles muchas veces durante las pruebas.
Comentar para los que estamos mas cerca de UK y podemos sintonizar su haz (UK:-rofl2), que posiblemente tengamos cambios muy pronto, la referencia es el tp 11053 H 23000, normalmente esta interferido por los tp's proximos y no lo puedo sintonizar, anoche nada y hoy lo puedo sintonizar perfectamente, la ultima vez solo duro 24horas, ya realice una foto con el sintonizador y lo que ve el analizador de espectro para comparar con las viejas que tengo de otras veces.
Sin tener en cuenta la posible interferencia de....
Eutelsat25B/Eshail1 at 25.5°Este en 11046 H 27500 3/4 (verificado ahora y las otras veces).
Badr6 at 26.0°Eeste en 10930H 27500 3/4 (como referencia del satelite).
En las fotos del analizador de espectro marcare el tp 11082H(haz Europa), la señal es muy muy fuerte.
PD: Las fotos del analizador tardare un rato en descargar.
