Topic for general comments once 2G is on station and the transfers from existing Birds commence.
Signal reports to the dedicated regional Topics instead, please.
11200h low power of me becon now
Tururu
Assembled with recycled parts
Recycled as the owner.
How much is a jump ? Could it be that 2G goes to 28.5 to the position of the Eutelsat ?
No.
Each jump to 14Voltios are 0'1º.
Adjusted maximum antenna signal:
CL4, 5USA , Showcase and Bliss.
I need 15 extra jumps to this signal to be localized beacons G2 that are not present in 28'2ºE.
11198 Mhz. H
11025 Mhz. H
10956 Mhz. H
No.
Cada salto a 14Voltios son 0'1º.
Ajustada la antena maxima señal en:
CL4, 5USA, Showcase y Bliss.
Necesito 15 saltos extras al este para tener señal de las balizas localizadas del G2 que no estan presentes en 28'2ºE.
11198 Mhz. H
11025 Mhz. H
10956 Mhz. H
PD:
Tururu
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
I have low signal on 11618 H. (maybe not important)
i have signal low 11610v
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
now this are gone here in Tallinn
edit
09:20 utc
new tp (very strong here, same like 11010V)
11510V
edit. now gone ..
11495 V was also medium signal sort time..
Tururu
This morning it was necessary to modify 0'3º the position of the antenna to have 100% signal in tp test.
11054-11171H significant variations in the group, several off beacons.
10949'8Mhz active H level and much more, a new in 10958Mhz H, but is intermittent and is now very low.
Similar levels beacons Sunday Horizontal low band.
10949'8Mhz H .... ok
10958Mhz H .... intermittently.
10980 => 10978Mhz. and 10983Mhz. active ... ok
11026 H ... ok
11198 H ... ok
11533 H SR + 20.000..ok (??)
11610 H ... ok
Then I upload more photos.
Esta mañana fue necesario modificar 0'3º la posicion de la antena para tener 100% de señal en los tp de prueba.
Variaciones importantes en el grupo 11054-11171H, varias balizas apagadas.
Activa 10949'8Mhz H y con mucho mas nivel, una nueva en 10958Mhz H, pero es intermitente y ahora esta muy baja.
Niveles similares balizas del domingo en Horizontal banda baja.
10949'8Mhz H....ok
10958Mhz H....intermitente.
10980 => 10978Mhz. y 10983Mhz. activos...ok
11026 H...ok
11198 H...ok
11533 H SR+20.000..ok (??)
11610 H...ok
Luego subo el resto de fotos.
A week ago/Hace una semana.
Now/Ahora.
16_1_11171H.jpg 16_2_11171H.jpg View attachment 79557 View attachment 79558 View attachment 79559 View attachment 79560
Retired Mod
www.timo.me.uk
Strathclyde on DS has been posting again some info that at 01:00 on 18th June Eutelsat 28A transponders D7, D8, D11 will appear on interim temporary transponders on 2G. Then at 05:30 C1U and C1L will switch over to their their permanent slots on 2G.
He also states that ITV will start moving some of their transponders over to 2G overnight on 17th. Looks like 2G could be used quite heavily and may be of more interest to ex-pats than some of us had first thought.
cazhh
Elmshorn, Schleswig-Holstein
"overnight on 17th" does this mean the coming night (16. to 17.) or the next night (17. to 18.)?
Retired Mod
www.timo.me.uk
I was wondering the same thing so I have asked. Not sure as I originally thought things would start to happen on the 18 and 19th but it could be ITV are doing their moves earlier.
Looks like soon we should get an idea on how these UK spots are going to be for the ex-Eutelsat transponders and the critical ones used BBC/ITV/etc.
Retired Mod
www.timo.me.uk
He thinks it means early Wednesday morning but not certain.
Tururu
DS Strathclyde
Astra2G is scheduled for 01:00 on 18th June with the firing up of the 28A D7, D8, D11 transponders ......
Then at 05:30 the same night, the 'in earnest migration of the C1U and C1L transponders from Eutelsat 28A to their permanent slots on the Astra2G.
El "primer baile" al Astra2G está prevista para la 1:00 el 18 de junio con el "disparo" de los tp's 28A D7, D8, D11 ......
Luego a las 5:30 la misma noche, migración de los tp's C1U y C1L de Eutelsat 28A a sus slot permanentes del Astra2G.
Thanks for the info/gracias por la informacion.
PS: Errors, especially translation allowed/Se admiten errores, sobre todo de traduccion.
cazhh
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
I have now 11465H with 3m
blank, no lock , no nothing..they testing maybe different beams..
also something 11175H
the itv group have several tp
10758 V
tp 44
10832 H
tp 49
10891 H
tp 53
10906 V
tp 54
10994 H
tp 59
11053 H
tp 63
11097 V
tp 66
it all tp move to 2g ?
In my area I have not noticed today any signal change between 10700-11700 MHz.So it is just like yesterday.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
There were some Freqs changes on Sky UK, don't know if this is a normal routine or something to do with the arrival of 2G.
e.g Sky action SD had a freq of 11836 H 27500. Now its 11934 V 27500 5/6.
National Geo Wild had a freq of 11603 V 29500 DBV-S2. Now its 12187 H 27500 5/6.
no lock here it real change ?
