Tururu
Assembled with recycled parts
- Jun 3, 2006
Recycled as the owner.
- North of Madrid (28703 Spain) -3Km of IKEA (40.545847, -3.612012).:-)
Daniel74 partner with small antenna also indicates:
El compañero Daniel74 tambien con antena pequeña, indica:
The antenna did not move, but that does not stop "dancing" is the signal Astra2G as UK footprint is critical, probably lost channels.
La antena no se movio, pero el que no para de "bailar" es el Astra2G y como la señal de la huella UK es critica, perdio los canales seguramente.
These channels are moved to the UK beam Astra2G/Estos canales se movieron al Astra2G beam UK el 17-6-2015.
See the circle of Astra2G, not wasted, the second graph allows you to see the variation of the orbital position, each circle is a day.
Mirar el circulo del Astra2G, no tiene desperdicio, la segunda grafica permite ver la variacion de la posicion orbital, cada circulo es un dia.
http://www.satellite-calculations.com/Satellite/satellitemotion.php?26/171/0/40364
Leave a photo, they are updated daily/Dejo una foto, se actualizan diariamente (28.52 <==> 28.24).
Adjusted length values as usual/Ajustada la longitud, valores como siempre.
11067 = 9.50dB Señal/SNR59% AGC99% BER 0 ITV Encore HD (DVB-S2)
11097 = 9.00dB Señal/SNR56% AGC99% BER 0 21000/10/20/30 (ITV HD)(DVB-S2)
11126 = 9.50dB Señal/SNR59% AGC99% BER 1 Channel 4 HD (DVB-S)
11067
11097
11126
PD:Buena pesca/Good fishing.
Hello from 1 day ago I lost frequencies astra 2g 11068V, 11097V and emit Stv 11126v where hd, hd UTV, ITV and Channel 4 hd hd, I entered with 50% signal, someone has got it or that has moved me the antenna?
11067
11097
11126
