3.1ªE Eutelsat 3B
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Sorry if I am wrong but I could not find a previous thread on Ku that I could add this post on, only on the C-band section.
I like the abundance of low SR's, sad but.....! :D
Eutelsat 3B 08.20hrs.
11478 H 1480 ALM channel3.1E_11478,652_H_1480_(2015-09-11 06.52.15)_dump.ts_000009815.jpg
12559 V 1500m Asia TV
Tururu
Assembled with recycled parts
Recycled as the owner.
Thanks for the info.
As you indicate, this satellite has many tp's with SymbolRate very low, not all tuners down from SR2000 (Vu + DUO2 for example), but in DreamBox800S-HD works fine until SR332, with a good antenna, all sorted.
Gracias por la informacion.
Como indicas, este satelite tiene muchos tp's con SymbolRate muy bajo, no todos los sintonizadores bajan de SR2000 (Vu+DUO2 por ejemplo), pero en la DreamBox800S-HD funciona bien hasta SR332, con una buena antena, todo solucionado.
Some photos of some channels with low SR, the satellite comes very strong, as always.
Unas fotos de algunos canales con SR bajo, este satelite entra muy fuerte, como siempre.
PD:Buena pesca/Good fishing.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Have a great weekend.
Tururu
It's upside down, thanks to you.
The other day (30-8-2015), update the general list that have since 28'2ºEast to 4'8ºEast, more 30ºWest, staying just outside the satellite.
Review this position last night and update the list of channels almost 100% since last year untested.
There are links and much dance names, the good thing is that we have very good sign and is not under SR problem, or little separation between the tp's (for a standard tuner can be a problem).
Es al reves, gracias a ti.
El otro dia (30-8-2015), actualice el listado general que tengo desde 28'2ºEste hasta 4'8ºEste, mas 30º Oeste, quedandome justo a las puertas del satelite.
Anoche repase esta posicion y actualice el listado de canales casi al 100% desde el año pasado sin revisar.
Son enlaces y bailan mucho los nombres, lo bueno es que tenemos muy buena señal y no es problema el SR bajo, ni la poca separacion entre los tp's (para un sintonizador estandar puede ser un problema).
PS: We will try, thanks/Lo intentaremos, gracias.
Laser
Another good one to try as always is Libya One 11049H 1000 DVB- S2 MPEG-4 8PSK
The Dr HD F15 gets it OK with the odd 'glitch' :D
Tururu
When the tuner is approaching its "limit", give him a few more seconds to "open" the channel.
If the signal is good not have problems.
In Hispasat I can have "normal" channels almost 100% and radio channels with SR500 or the smell when we perform the search, still you need to tune the antenna to 100%.
Cuando el sintonizador se acerca a su "limite", dale unos segundos mas, para que se "abra" el canal.
Si la señal es buena no tendras problemas.
En Hispasat puedo tener los canales "normales" casi al 100% y los canales de radio con SR500 ni los huelo cuando realizo la busqueda, siendo necesario afinar al 100% la antena.
Tururu
So is the tp 11049H1000 in spectrum analyzer, expansion to see well.
Asi se ve el tp 11049H1000 en el analizador de Espectro, ampliacion para ver bien.
Looking for best tp in 11048, the signal that we can disturb 11050.
Busca el tp mejor en 11048, la señal que tenemos en 11050 puede molestar.
I will pass this trick/Se me paso este truco.:-rofl2
daaihe02
Channel master 120 cm .
Sweden
I live in Northern Sweden. i have Echostar dish 1.2 m , Inverto black ultra , Vu+duo2 and DR HD F15. I can get all Ku - band transponders except Waar Sport ( 12566 V, 2750, 2/3, 8PSK ) . can some one confirm receiving stable signal from WaarSport. Thanks in advance.
Archive4
Checked the frequency on Flysat, it states 12568 V, either way, I cannot see anything there at all. Can get Waar HD no problem, so figure the sat sites could be wrong, or it´s on a different beam.
daaihe02
Sweden
Thank you for your help. well, if you can not get signal with 1.8m in Spain , i would not get any signal with 1.2 m dish in sweden. Some thing is wrong about parameter of waar Sport in Lyngsat and Flysat
Archive4
Must point out, only using the motor 1.2 m to check. The 1.8 is still looking at 52E and getting nothing!
VodzigorLans
Setup is down atm
RU, Saint Petersburg
This channel went very low last months, it was as high as WAAR HD. I do receive from time to time...
As you can see there are stream errors but maybe it is because of my card using receiver it should be better.
Anyway it is not watchable for me...
daaihe02
Sweden
Thank you mate. i could get signal from waar sport until april -2015.
daaihe02
Sweden
Thank you mate for your efforts.
Archived-1
Persona non grata
uk
Locking this ok at my location 1.2 CM dish. Please ignore my satellite position in screen grab.
Tururu
With Vu+DUO2 I guarantee you will have problems, no matter the signal does not work well below SR2000, review various TP's and until 1450 usually works almost well, but now with SR1100 after 30 seconds of "black" and no signal opened the channel (one sample photo) with SR 1000 not opened any channel.
In relation to the channel WAAR SPORT in 12566 V 2750, he choked channel, varis minutes after no signal intermittently opened and closed, some pictures.
The channel list is the same for the 2 tuners and engine settings, even put the VU+DUO2 as slave DB800S-HD with the necessary protections (insulator) and the pictures show the difference.
VU+DUO2 testing is dual tuner satellite, at the time also conducting tests of simple tuner in Hispasat with the same negative results.
Con el Vu+DUO2 te garantizo que tendras problemas, da igual la señal, no funciona bien por debajo de SR2000, revise varios tp's y hasta 1450 suele funcionar casi bien, pero ya con SR1100 despues de 30 segundos de "negro" y sin señal abrio el canal (una foto de muestra), con SR 1000 ya no abrio ningun canal.
En relacion al canal WAAR SPORT en 12566 V, 2750, se le atraganta el canal, despues de variso minutos sin señal, intermitentemente abre y cierra, unas fotos.
La lista de canales es la misma para los 2 sintonizadores y la configuracion del motor, incluso puse el VU+DUO como esclavo de la DB800S-HD con las oportunas protecciones (aislador) y las fotos muestran la diferencia.
Las pruebas del VU+DUO2 es con sintonizador doble de satelite, en su momento realice las pruebas tambien del sintonizador sencillo en Hispasat con los mismos resultados negativos.
WAAR SPORT (12566 V, 2750, 2/3, 8PSK) ==> DB800S-HD
WAAR SPORT (12566 V, 2750, 2/3, 8PSK) ==> VU+DUO2.
More photos/Resto de fotos.....
Archive4
Following Tururu´s post have checked again this morning.
Have noticed I have a " duplicate " of WAAR HD on 12568 V 3560 as well as 12571 V 3560, closer to where it should be.
When sitting on 12566 V 2750 ( as the pre determined txp on the VU+ ) I am getting intermittent signal for WARR Sport, so suspect the strong signal here for the HD is killing the Sport signal.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Receiving Libya One on 11049 H Symbol rate 1000 on DB 8000, BUT with an Alps Tuner, added to DB - Tried also with DB800se but no joy.
Seems that the on board Tuner of DB800se find it hard to process this low S/R.
daaihe02
Sweden
Thank you for info mate.
