Weather Sat Images thread..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Last one for now ..
Couldn't resist grabbing this one as it passed almost directly overhead..
Noaa 19 ..
Passed over practically skimming the roof at a max elvation of 80deg ..and an azimuth of 345 deg.
It was still visible with an elevation of 9deg as it hit greenland..
practically no interference ..it being a cloudless Sunday afternoon..
Nice..
rgds
Whats happened to the ground overlay? Has there been a big earthquake?
That is so cool to be able to do though :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
error with processing I think AS ..
If I still have the raw data .. might try reprocessing..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So re-processing the raw data produces the same error sadly..
but ..there is an option to move the map overlay ...
It's a tricky operation ..getting it right ..but this is a modded image with some overlay tweaking..03131352modded.jpg
I guess with some patience I could improve it some more ..but hey ...like buses ..another will be along soon..lol
Archive4
No gear to play with this topic, but I want the updates, so chipping in so I get alerts!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Twitter user usa_satcom is receiving high-resolution weather pictures at 1.7 GHz from NOAA satellites.
USA Satcom on Twitter
So ..presumably the remaining active apt noaa birds also broadcast hi def images on 1.7 ghz ..as well as the lower frequency 137mhz ....during their passes ?
Nice images by USA Satcom ....but not much actual info on what is being used ..
We know its SDR ...but what else ?
what antenna ...what polarisation...does it require decoder software other than wxtoimg ?
I would love to have a go myself ...but more info is needed ...not just pretty pics on Twitter...
..and I definately dont tweet ..ever...not even if you stomp on me ...
..I might sqeak a little tho'
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
This 1.7ghz downlink for HD images must be a well kept secret ?
I put this in google search ...'apt noaa 19 hd downlink frequency' ...and drew a blank on all but 137mhz ?
where can I get more info I wonder ?
Perhaps Terryl can shed some light on this ..
He does afterall run a successful weather station/site.
smoggy07
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks Smoggy ..
That is indeed useful info ..
First I shall be looking to see if I can even pick up hints of signal on a close noaa pass....though not expecting much ..as although I have a the right antenna polarity wise ...it is not tuned for such high frequencies..
I guess I now need to see if there is possibly a QFH design for 1.7ghz ?
SDRplay covers up to 2ghz I think so covers the correct part of L band spectrum.
As tracking with a conventional dish system wouldn't be practical.
I was right it seems..
a different decoder is need ..other than wxtoimg..
This I hope will make an interesting project.
cheers
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ...
From what I read ..L band reception of apt sats is very much more directional ...and requires a dish ...or yagi ...and tracking hardware/software.
This is not really surprising as we know that UHF TV requires a directional aerial and is still round about 700 > 900mhz
L band being higher still..
I was hoping that a mini QFH would solve the tracking problem ...and give acceptable results..
Antenna experts ..feel free to jump in at any point..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ...
This is a commercial QFH (mini) designed for 5.8ghz
5.8ghz FPV Quadrifiliar Antenna - #1 FPV Antenna - For RC airplane or quadcopter
Perhaps someone makes one for L band ?
Not found one myself as yet ...sadly
Just sent this guy a message via Ebay ...as he also does a 2.4ghz version..
Available in RHCP or LHCP ...
So it cant hurt to ask if he also makes them for 1.7ghz ?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Whilst it is interesting AS ...
It is much what I already have and aimed at the LF 137 mhz range..
rgds
VS
According to the second part of that you should be able to used your QFH to decode the data from some of the Cubesats :D
battenfan
1.2m pf
60N 18E
There seems to be a HRPT signal on geostationary Meteosat @0W linear polarized.
UHF-Satcom.com - L-band reception
Paging @uhf-satcom.com
HRPT programs - from David Taylor, Edinburgh
I believe uhf-satcom's data is out of date. They have stopped transmitting the wefax signal long ago.
Their HRIT/LRIT on 1694.5 MHz is probably encrypted, their retransmission of them on ku band @10E definitely are.
EUMETCast Service
The encryption is described on page 95 in the pdf, MSG Ground Segment LRIT/HRIT Mission Specific Implementation
Technical Documents — EUMETSAT
Might as well put my sketch of a 12 cm waveguide for 1.7 GHz on the shelf for now.
QFH Antenna it is then.
