Help Required Trying to re-use a MAG250
Archive4
I am trying to make use of a MAG250 which I was given as the supplier wanted too much for the annual subscription. I have managed to delete the portal so the box now loads to the embedded portal and have gove into the IPTV option.
Within this is an option to load IPTV channels from a list using utf-8 encoding, then asks for a url to load it from.
Has anyone managed to do this successfully ? and if so are the UK channels geo-blocked ?
If what I´m asking is not permitted under forum rules please remove or lock the thread
smoggy07
Put into google or your preferred search without commas "IPTV M3U LIST UK TV" or look for "husham m3u list" and that should unearth a few .m3u playlists with a few channels inside for you to play with
Pastebin links should work too so if you find list of individual channels or you want to mix and match channels from different lists, you can make up your own list and upload it to pastebin
Admin/Mods: if I've overstepped the info line, delete the offending info/comments
Archive4
Thanks, I´ll have another play over the next few days, confused me when the MAG asked for uft-8 coding, I saw a couple of m3u references but thought they were different
smoggy07
A .m3u playlist will have lists of channel streams and their tags
#EXTINF:-1,UK: BRITISH EUROSPORT
http://123.456.7.89:8000/live/bavaria/BE.ts
I think the ref to utf-8 encoding is the way the tags are formatted in the playlist
davemurgtroyd
Oxford
Oxford
http://xxx.xxx.x.xxxx/live/bavaria/BE.ts
Theft of pay TV should not be discussed or encouraged on this forum
The IP address posted by smoggy is invalid (http://123.456.7.89)- its just a demonstration of how the m3u playlist is formatted without giving away whatever that actual address is.
Haydar1972
MAG250
sweden
Please support me with your experience
I have same problem as yours
I have Mag250 and I need to delete the portal or upgrade it but never successed with that becaz it is locked by the Company with their own setup and enviroment variables.
I observed as you mentioned that you manage to delete that portal
PLz support me with youe ideas How you did that.
thank you
Archive4
Sorry, not ignoring you, not in country at the moment
Will reply in a day or two, on my return to Castle Milamber
