Green Bank Observatory
A quick search on the site confirmed it has been a decade since somebody mentioned SETI, and following the latest 'Click' episode, here is a thread on all things extra-terrestrial and broadcasting.
first up, the project Breakthrough Listen, which pays a substantial amount to hire the bigger radio telescopes to listen out for the aliens, intelligent or just noisy.
Breakthrough Initiatives
The latest Click programme, about 12 mins in. a true quiet zone under threat of closure.
Click, Quiet Zone
Terryl
Custom built PC
If you all want to listen in to some very eerie sounds from space then all you need is a long wire antenna and a radio receiver that can tune to around 20 to 25 MHz.
Then at night when Jupiter is up and you can see it, then tune through that band, I sit there fixed to the radio listing to this sound, it gets quit beautiful at times.
Here is some info for setting up for this.
http://www.radio-astronomy.org/pdf/qex/radio-jove-proof.pdf
This works best if you out in the boonies, as sometimes the local RF noise from around the city can interfere with this, I use my Yaesu FT1000, it has some very nice filters to knock out the mess.
This works best if you out in the boonies, ......
Easy for you, being in a Mars crater.
Terryl
Custom built PC
You want to listen to some of this stuff lookie here.
http://www.astrosurf.com/luxorion/audiofiles-jupiter.htm
US declassified encounters
The second could be a scramjet prototype, though it is difficult to gauge the speed from the video.
There are higher quality images still under wraps, the detail in the saucers could be cleaned up with modern processing
