Advice Needed TM5420HD C1 + Super + message "Not compatible with this STB".
Spiff
Mullion Cove Cornwall
shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
Good evening now that I have a stable mechanical system, I am progressing to installing some patches from the download centre to hopefully decode.
This may not be the right patch as it is new to me and as of yet I do not know exactly what I am doing.
But it and others will not install, so it is difficult to progress : )
I get a message "Not compatible with this STB".
Is this to do with the model or the operating system I have installed ?
Please see images.
Thank you for your time
God Bless Spiff
Connect your box to your router than navigate
Entertainment
TMOnline
Internet Update......
SW - average.......
PH
TM5402 -M3
then put patch 146 on it.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Entertainment
TMOnline
SW - average.......
PH
TM5402 -M3
Thank you kindly for the information.
It downloaded so I am assuming it installed as well at the same time.
In system information nothing has changed, is that correct ?
I did reboot.
Can you say what patch 146 should do ?
A carrier has just delivered A 4K box my Christmas present, so I cannot play with that yet : )
Thank Spiff
Its the Phantom patch - got a few goodies built into it. Try the Swiss HD channels on 13E - they are currently opening on it. You may need to turn the patch on which is done using a particular key combo. Which I cant remember atm! 8282 maybe?
Let me go and have a look to see if I can find it
Serafeim
5 dishes, Technomate 5402 M3
Arta, GREECE
Spiff, you have model 5402 M1 or 5402 M2. You can find the update here.
^^ 18 months old - wont open much nowadays!
M1 & M2 patches are also available on the download method - just pick the applicable bit of s/w
Serafeim
Arta, GREECE
I always prefer to update with usb stick.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Good evening Thank you for that.
Are you saying that : -
TM-5402HD C1+ Super +
Is a M1 or M2 not a M3 ?
Spiff
Serafeim
Arta, GREECE
Exactly. You can easily check the front side of your stb to see the model you have.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
The model number on the front panel is TM-5402HD C1+ Super +
No Mk number but you are saying it is either a MK1 or Mk2 with the above model number
Spiff
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
11.525H 29.697 is as far as I can tell a Swiss HD info channel.
It said online that it was free to air, but it showed as $ and was blank.
I set CAS Viacess in the CAS menu
I set number 82 82 00 into the Ident box nothing apeared.
Changed it back to default 83 00 00.
The Info channel is now showing a picture without an $.
I do not know if what I did was correct, or if it caused the ifo channel to apear : ) ?
Images attached : )
Spiff
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
So you have M1 model.
Thank you for that : )
The later models I asume say MK2 or Mk3 perhaps.
We supply radio service data, the fIrst model is never called a MK1, it is only the updates that are Mk2 and so on.
It apears to be decoding a channel as I have posted above, but not convinced yet : )
All very interesting.
God Bless Spiff
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Thank you there is nothing like a picture : )
The decoded channel is now encoded again, oh well time for bed : )
I shall play another night.
Thank you for all your help Spiff
Serafeim
Arta, GREECE
You should have picture at rsi la 1, rsi la 2 channels. Try frequency 10971, H, 29700 as well.
... This is the front logo of one of my recent 5402 HD M3 Spiff
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Thank you.
With all the Super + and so on I had always thought that I had the latest model.
Is there a lot to be gained in up grading to the MK3 ?
Better perhaps to wait for a 4k version now ?
God Bless Spiff
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Thank you The MK1 patch did the job.
I had thought I had a M3 but this was incorrect.
God Bless Spiff
