jpsr
- Aug 27, 2009
- Age
- 43
- 1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
- Mullingar, Ireland
It's been a while since I posted on here, had a break from messing around with satellites, but the bug is back.
I have a few new 1m channel master dishes and was wondering about using it on a stab hh motor, can't seem to find any 120 models for sale.
I've seen posts over the years with people using 1.2 dishes on these motors with the rings fitted, but judging by the ones I have, they are very heavy and so is the mount alone.
The 1m I have seems a lot lighter and the mount is smaller and lighter too.
The mount takes a 60mm pole and the stab around 50mm i think.
There is a lip on the mount that can be cut to tightin it further.
The dish and mount could be light enough to make this work, as it would be installed in a sheltered area also.
Has anyone ever tried this with the 1m, remember I have a smaller and lighter mount compered to the one on a 1.2.
Thanks in advance.
Thanks in advance.
