Just Sharing This 2.2mtr Elite / Precision resurection... Part 2.
1.8 CM dismantle time has come today ...
Just a box of bits and bobs now , Old Precision triangle back bracket refurbed, polar mount bearings checked and all ok. Platform prepped for 2.2mtr to be installed.
A few dismantle pics
That's a very handsome dog supervising the day's events.
He's in charge!
Thats our Abbey, she gets a face on if she can't be with me outside bless 'er.
... Got me bitch by me side and me reflector mounted, need to do a bit of paint touch up around the edge that was sat on the floor previous. Will try and get a cable connected to a temp Cband lnb tomorrow .
RimaNTSS
Some SAT-related hardware.
N-E from Riga
@John you can not do anything without proper supervision of your 4-legged friend. :)
When are you putting the final dark coat of paint on the reflector ?
... now ready for final touches
That's looking absolutely great John. Very well done.
Magnificent, a site to behold, well done.
The semi gloss paint finish looks good, its the right balance, a matt may have been too dull and a full gloss to bright, semi gloss finishes it off a treat.
Rgds
Rgds
Yep, it's not turned out too bad. It looks very similar to the ones i was looking at down at Elite's the other week. Out of a possible three options of applying the paint ie: brush/roller/spray, then i think to spray would have been the best finish, but finding a suitable paint that could be sprayed on would then be another task to do. Iv'e a 20yr old or so 1.2 Precision and the paint finish on that is a slightly more matt finish but some of that could be down to weathering over all those years ??.
It looks fantastic J :-applause
Cheers matey, i'm just off outside now to try and get a functional Cband lnb up and running on it. Beautiful sunny day here at the moment.
blademedia
Sky
Crack on J :), a lovely day here, going for a drive out into the country :( will play with my dish at tea time :)
The Zinwell to AV-Comm barrel was a tad too tight for smooth rotation of around 200° so needed to be sorted as it kept binding at the extreme end of travel range. Parallel alignment of barrel shaft and Zinwell shaft is fairly critical to obtain smooth operation over a wide range of travel.
Next job is to re-fit the camera at the bottom lip of reflector to keep an eye on what the polarity servo is doing and then final focal point / scalar adjustment position for optimum performance.
Not much to see today, fabricated a new bracket for the dish cam to fix to the outer reflector ring.
... just an end of day pic of the new girl Ellie basking in the late afternoon sun looking at 0.8° W. Installation is nearly all complete now.
RimaNTSS
N-E from Riga
Nice picture! I wish everybody here, in the forum, able to take such a shots in the tight space! You should start tutorial lessons on that!
