2 Cards in system?
packetstormer
1.1m Triax dish, TM2300 motor. 2 x DM800HD, 1 DM500, 2 x Sly HD. 1 60cm fixed (Astra 2D).
Ireland
Does anyone know if it's possible/easy to put, say, 2 SkySat PCI cards into a system and configure them so I can record one program and watch another?
I am looking to build a complete replament for a $ky HD box and would like similar functionality.
packetstormer
Ireland
mklobu43
sky star hd
Croatia
Did that, two years ago with two skystar 2 cards in 1 pc,
but you must know they do not supported hd dvb-s2 system.
Here is the link where i explain, it is on croatien language,
but there a pictures so txt is not that important... :)
http://www.novisf.com/wbb3/digitalna-televizija/dvb-kartice-i-internet-preko-satelita/tutorials/49165-driveri-4-4-0-2-ss2-u-kompu-radi/
Btw you can do whatever you want with two cards working in same time ;)
mklobu43
sky star hd
Croatia
RedDwarf
Sky Minidish and Sky Digibox signal now detected
Core 2 Q9450 up to 3.5GHz
Gigabyte GA-X48-DS5 motherboard
4GB DDR2
Gigabyte 3850 Gfx card
Mystique Dual DVB-S2 PCI-e
Pinnacle Dual DVB-T Pro PCI
Central Midlands, UK
Or if your PC supports PCI express, get a dual tuner DVB-S2 card like I got less than a week ago from DVBShop Germany. They cost about £150 delivered.
