Wanted 24 inch actuator/jack
Chris James
None
Southampton
Hi all
So after getting a dish sorted thanks to purplemarina
I now have a 1.2 meter channel master dish and polar mount but I’m in need of a actuator also need an LNB
Mickha
North West
Do you have a channel master feedhorn, which connects to a c120, or flange LNB?
Your motor/positioner depends on your setup, but I would advise a decent 36" actuator, which should provide a decent satellite arc.
I found a 36" is just more than enough for a 1.8m polarmount system running full East/West, though it is the superior IRTE type.
Hi all
Try to locate an official feedhorn for the reflector, it makes all the difference, plus no more unscrewing the clamp screws.
Chris James
None
Southampton
If you know of one or where I could buy one that would be great
A long neck LNB will be fine to begin with. My CM feed horn came with a couple of SMW singles which were at the time comfortably beaten by a universal Inverto Black Ultra. If you want a feed horn then there's one on eBay:
https://www.ebay.co.uk/itm/Satellite-Skyware-Channel-Master-KU-Feed-Horn-Swedish-Microwave-Digital-KU-LNB/174619002495
The LNB is probably single band, single polarisation so no good for general use.
Chris James
None
Southampton
Hi thanks for reply
No I don’t have one but I’d be happy to buy one if you have one I’ve no idea what I need I was just going to get a universal lnb to start but want it to be a bit future proof
I’m going to use my old maspro sac 80 positioner I’ve had for about 25 years
Any info greatly appreciated
Chris James
None
Southampton
Gonna go motorised really
Chris James
None
Southampton
Got one thanks for the heads up with the one on eBay
Chris James
None
Southampton
Bought it so next step actuator
Still looking people
Satellite Superstore have them if you're willing to pay.
