28.2E Astra and 13.0E Hotbird
cjhammer
DB500s
Reading, UK
Hey,
My dish is currently pointing to 28.2E Astra for BSkyB, I was hoping to get some more channels on 13.0E Hotbird but only get about 16 mostly BBC 1.
What’s the best thing to do, should I move the dish towards Hotbird more and what overall effect will it have on Sky?
Regards,
CJ.
Mickha
North West
Hi cjhammer,
welcome to the forum.
I doubt you're getting hotbird, 13E, as your dish is obviously pointing at 28.2E.
What is your dish size?
Do you have a motorised dish, or have you got a fixed dish with multiple LNB's?
You need to have your dish, or LNB, pointing at 13E to receive those channels it is not just a case of scanning in the frequencies for hotbird.
Can you please post some more information and we'll try and help.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
If you are getting BBC1 on Hotbird, you are not on Hotbird.
If you move the dish towards Hotbird (assuming it is a single LNB setup) you will lose Sky.
If you want Hotbird, you will need a 70-80cm dish and another LNB on the dish, or alternatively put up a completely separate dish possiby motorised for a wide range of satellites or fixed just for Hotbird.
Robbo:)
quasarbsb
SkyHD
South East UK
Hotbird ? You mean Eurobird ? more info needed dude.
Regards.
satelliteman
Your getting confused.
Eurobird is at 28.5e and is at the same position as 28.2e from earth.
Hotbird is a totally different satellite and is positioned at 13e :)
