moordown66
Had a search but couldn't find anything totally specific on this...
I have one dish with 2 x lnb's (Astra/Hotbird) going via a diseqc switch into a Technomate.
I also have a communal Sky dish which I also want to add to the Technomate. This is where the problem starts.
This comes in via internal cabling and out through a wall socket so I can't add it to the diseqc switch which is outside unless I run co-ax out to the switch from the inside wall which really isn't an option. As it's a communal dish I can't get up on the roof and fiddle around with the co-ax to run it down to my diseqc switch either!!!!
Is it possible to run Astra/Hotbird into my existing diseqc switch, then out of there into a second diseqc switch which would also contain Astra 2...and how would you go about setting that up in the receiver menu?
Or is there another, more simple way?
