- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
Not a squeak on 30.5E or 31.5E
forget this one A/S I am @ 31e :-0ok I have a lock now 12526 v 2500 is coming in at 60%
You pay a premium price for a premium product and look how it repays you!Analoguesat said:Sliced my hand open on the bloody Triax as well
That arc already has quite a lot of satellites, I'd say enough to choose for a motor:Analoguesat said:In the secondary location up the garden Id get ~28E -> 57E (trees in the way west of 28E, then the hill in the way out past 57E)
Well, you are basically saying they are against the trade description act as they are not remotely fit for purpose. To call that a bracket is beyond taking the p. That means we should all be compensated to the cost of the dish in a big class action.Tivù said:Well described - that's exactly what happens. I still get caught out by my perfect alignment being destroyed when tightening up the slider.
And as my own TD110 is on a Patio Mount/Slab, I can fine tune Elevation by hammering plywood wedges under the front (or rear) corners. Works well until they turn to mush!
Nothing that can't be solved with two motorised dishes.... ;)Analoguesat said:Decided theres no point - any motor here would only cover about 20-30 degrees of arc unless its 8 feet up in the air which makes it far too vulnerable to the wind funnelling down the valley and also far too visible to passers by I only get away with the existing dish as the neighbours dont care about all the metalwork & they are well hidden from the road most of the year
If you have seen the recent photos of the dish farm in location 1 by the hedge I could get 5E -> ~28E (trees in the way west of 5E then the hedge gets in the way past about 28E)
I know I do well with the sats I pull in with the kit but in reality its a rather difficult location and I just have to make the best of what Ive got here
