3D files : channel Master feedhorn adapteur
zorrin
Specialised contributor
France
www.facebook.com
CM 120 Ku 52°E to 45°O
CM 120 Ku 50°E to 45°O
CM 120 Ku SDR 25.8°E
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
GTMedia V8 Nova, V8X, V8 UHD 4K, V9 Prime
Edision Piccollo
france
Here you will find the 3d plan and 3d print file of the Channel Master feedhorn adapter.
  • CHANNEL MASTER FEEDHORN ADAPTER 3D.rar
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
how much you charge zorin?
zorrin
France
www.facebook.com
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
Edision Piccollo
france
There are many people on eBay offering 3D printing services such as:
I have not used them but has to be worth getting a quote using the file zorrin kindly shared. I think ABS is the correct material.
zorrin
France
www.facebook.com
CM 100 Ku 5°W
CM 100 Ku 9°E
CM 90 Ku
Visiosat Bisat Ku
Visiosat 70 Ku
Selfsat 2x Ku
Selfsat 2x Ku
Octagon SF8008
Edision Piccollo
france
The problem with ABS is the shrinkage of the material, a material with fiberglass inside will be better I think.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
There is my version of the adapter. It allows fine-tuning (closer/further from the dish) the position of the LNB/feedhorn, it has ~45 mm freedom of movement.
Interesting, you would be the right person to ask if you have identified an issue with the 1.2/1.8m focal point and feed as per the original specifications from Channel Master.
