alfa155btcc
- Aug 2, 2007
- Age
- 54
- I have a 85cm Faval Dish with 0.2 titanium lnb and alsat dark motor running off of a Technomate 1500 Ci Super
- Bucks
Hi Guys,
I have a TM 1500 Ci Super and Kaon Stb`s, working off of a Triax 95cm dish with Darkman Motor.
I want to add a Freesat that my friend has lent me for a little while so i need to connect 3 stb from my one satelite motorised dish.
Before when i just had the 2 stbs i used a 2 way splitter one cable in 2 out works fine so i though i would go to my local diy store and try and get a 3 way splitter . I could not find one so i bought what i found which was a 4 way splitter. i wired it all up with lead from dish going to IN and then the other 3 stbs on 3 of the 4 outs, to my dismay found that only my tm1500 ci super worked not Kaon and no Freesat. so i had a little tinker with cables and found that if i changed wires round it was only 1 of the outs that worked and that was the bottom left one.
Can anyone help me out with some sort of solution please ????
Cheers
alfa155btcc
Cheers
alfa155btcc
