49 east
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
I have seen on LJ's that there is a station called RTR Sport on 49 east c band.
What exactly does this mean, does anyone get this channel in the UK/Western Europe and do I have a chance with my puny 1.2 meter with this?
Funny thing is, it does not even appear on my list of sats in the Dreambox sat menu....
T_G
I moved the thread here as no response in the fringe reception. Anyone?
twag42
Amsterdam,Holland
i think he's looking for the man utd match ;-)
TWAG
Well the power for the downlink across the UK seems to be about 38dbW . Which equates to around a 1.5m dish minimum. Plus C-band kit of course.
RTR Sport is on 13E Ku band, but I cant imagine that version showing the ManUtd game.
T_G
RTR sport on 13?? what are the station details?
Oh - its planeta sport on 12597 Im thinking of.. :-ohmy
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
While you are in LJ's click on freqs.
RTR only shows rubbish. :-Cbigsmil
T_G
yep normally. Of course I went to LJ freq page, but there was a bit of a confusion here about the name of the station...
Still, I am intrigued about this 49 east sat...a mystery sat!!
No mystery - its Yamal 202 serving Russia in C-band
iwol
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
hi but is anyone getting this sat with a 1.2m dish in the uk
T_G
Can you give me a quick pointer how the numbers convert to dish size? also, I am in Germany...
I use this one T_G:
http://www.flysat.com/dish.php
Take the appropriate power line for your location, then convert using the chart. It gets a bit theoretical for lower powers / bigger dishes, and you will find charts disagree.
T_G
Looking at the chart my 120 should be ok...I will try to play with it.
T_G
Does it need a special LNB because it is circular??
john_graydon
Dublin....Ireland
Was having a look myself, cant get it here with only a 1mt dish. Freq i got was 3706 L 15550 3/4 TP 4a (Planeta Sport) Might be of some help. Looks like a analog freq dont it, listed as Digital FTA. Maybe if you get a new set of settings with 49e listed in it, might help.
Those are most definitely digital parameters ;)
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
3706 L will need a C band LNB left hand Pol.
L.:)
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
all dishes are circular :D
is there not a site that has all the satellite footprints on?
