4k on a non 4k tv set?
daro2096
No setup at present
Consett, Durham
With a 4K capable receiver will a 4k channel downscale on a non 4k TV set or will it not display a picture at all or just display part of the picture? Can receivers be programmed to downscale 4K stations down to 1080p?
Tururu
Assembled with recycled parts
Recycled as the owner.
The 4K (UHD) receivers can reduce their output to 1080P to be able to use any TV, even 720 (for old TV HD ready) and less.
Some equipment has composite video output (VU + Uno4K), the Fashion 4K channel looks very good (Astra 19.2º):-rofl2
As best they work, considering that 99.99% of the channels in the best case are 1080P is setting to 1080P and then it is the 4K TV who performs the rescue of the signal to 4K (UHD).
If the TV is 4K (UHD), look who performs the best rescaling, put the receiver to 1080P and then to 2160P, which is of better quality.
Los receptores 4K (UHD) pueden reducir su salida a 1080P para poder usar cualquier TV, incluso 720 (para viejas TV HD ready) y menos.
Algunos equipos tienen salida de video compuesto (VU+Uno4K), se ve muy bien el canal Fashion 4K (Astra 19.2º):-rofl2
Como mejor funcionan, teniendo en cuenta que el 99.99% de los canales en el mejor de los casos son 1080P es configurando a 1080P y que luego sea la TV 4K quien realice el rescalado de la señal a 4K (UHD).
Si la TV es 4K (UHD), mira quien realiza mejor el rescalado, pones el receptor a 1080P y luego a 2160P, lo que de mejor calidad.
HDMI means backward compatibility is assured, unless part of your system does not pass the digital rights / content protection regulations.
NASA UHD displayed via composite rca connectors onto my ~7 years old old tv card in a 15 year old computer
Steve@10
Chester
cctvcameracentre.co.uk
Apple Mac with UAD Satellite
Chester
4K HD 8 megapixel images on a standard TV or CCTV 1080 p monitor?
I don't think you can achieve this as the circuits would be different and more advanced I'm not a tv engineer I specialise in CCTV cameras I know you can not achieve this on CCTV monitors you can use the HDMI for 1080 p but as far as I'm aware you cannot display 4K 8 megapixel images
I don't think you can achieve this as the circuits would be different and more advanced I'm not a tv engineer I specialise in CCTV camerasI know you can not achieve this on CCTV monitors you can use the HDMI for 1080 p but as far as I'm aware you cannot display 4K 8 megapixel images
Are you the new forum sponsor ?
Imagery of the NASA 4k channel on an HD ready television, a cheap one at that (read 'free')
Tururu
If the receiver has A/V output, you can also see it on an old cathode tube TV.
Si el receptor tiene salida A/V, tambien lo puedes ver en un viejo TV de tubo catodico.
