57E (NSS 12)
If you think it helps,here is my spectrum(10950-11200 MHz & 11400-1170 MHz) with the signal from the three spots(ME,CA,EA) on NSS-12 that I'm picking up in my area.To compare what's comparable,taking into account that we are both in different areas,with antennas of different sizes.
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
I spoke with a friend (member of Cy Sat Team) that has 2.4m prime focus dish and his recepion was the same.
Personally i checked +/- 5 degr. from 57E to see the level of SNR and everything was OK :-applause
mar-val
Slovakia,Zilina
Everything is OK , 11604H can be in EA beam . Cyprus is between main lobe E.Africa and side lobe in Europe.
So there has to be null zone somewhere near.
blademedia
Sky
Cant believe I am seeing it in the uk with a 1,2 dish
Kypros_Pambou
Greek Cyprus
Is not the first time that i see problem of a satellite beam coverage. About this satellite the ME beam covers and all Europe (better to rename )
About the freq. 11605 H (data) even on Flysat list exist a question from where the transponder comes ... CA or EA ...???? (Left side CAH7 and right side East Africa ) Personally i can't answer this question because i don't receive them
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Getting bwtv at 57E with 1.5 Dish, barely.
puteez
Octagon SF4008- 90e-0.8w
Ukraine
11522 Н 6285, MIR HD, TEST(МPEG-2)
CERIN
16,0 Е - 140,0 Е
Супрал 0,9м. , TBS-6925 (PCI-E DVB-S2 Tuner Card)
Russia
11587 H 16533, 3/4, DVB-S2/8PSK, MPEG-4. O"zbekiston Packaqe ON. s 31,08, 2017.
stephan94
Bavaria
Hello
with my 1.20 I can receive (next to ChadTV and BBC Programs) the new program TiGray TV
I do not have much reserve but it works. Encode_1080P_15.mp4_20171202_153054.348.jpg
Coviello
Potenza (Italy)
Prodelin 11ft (335 cm)
Windows 2000 XP
Southern Italy
In Southern-Italy (Basilicata, Potenza, halfway between Naples and Bari) I receive 11008 H 3254 with 14.0 dB and 11105 H 45000 with 10.2 dB.
The antenna is a Prodelin prime focus 3.4m and the receiver is Dr HD F-15.
Coviello
adonis1
3 New channels added today:
France 24 (English, Frence and Arabic) on
11105 H 45000 2/3 DVB-S2/8PSK MPEG-4
EastAfrica Beam
stephan94
Bavaria
Hallo
with a 1.20m Laminas antenna in Northern Bavaria I can also see 11008 H 3254, but only with 1.4dB.
MCelliotG
Thessaloniki, Greece
Today I received 11105H from the East Africa beam for the very first time ever. Signal is very marginal at 7.1db!
pontiend
Contibruter
south yorkshire
I have not seen DUHOK 11044V for some time now.
This is the best that I can do on this satellite.
Longitude is right so either the elevation is out a bit or the conifer next door is starting to block this satellite.I will have to wait for better weather to check the elevation.
It could be quite a while.:rolleyes:
TBS6983 100cm Dish
hitech2016
Satellites
Morrocco
Ajouter le frequance de duhok mangelement
Et laisser quelque second pour monter le signa.
Mod note: Please ensure all your messages are in English!
aceb
Prof Tuner 7301 /
Sussex
Duhok is still there but it takes a second or two to lock. Qellat is also still there but never displays correctly for me.
Attached below is today's scan result table and a few other pictures of some blind scans from 57.0 East (NSS 12).
I could only manage to detect the data frequencies, not even the faintest flicker from any regular satellite TV frequencies. For me, this was not extreme fringe, it was fart free zero fringe amidst a data hurricane. Definitely nowt of note here, on to the next...
Retired human
Anything on C band on this satellite?
There are frequencies listed on Lyngsat and Flysat. However until I fit the C-Band feed to the dish I wont know if I can receive any of them.
puteez
Ukraine
new frec 10973, 11552Н 11700 left
