7.0E-media stream
7.0E-
12507 H,500,1/2,S2,Multi 21-media stream,
12508 H,550,1/2,S2,Multi 21-media stream.
For those interested in the analysis, I provide these recorded streams.
Adam792
Cheltenham
Do you have any new dumps of these? Could be AAC data (128kbps) maybe, although the presence of multiple IP addresses inside the single PID 515 makes this less likely.
Here are the two dump files from 7.0E: 12508 H & 12509 H.
Thanks.
Adam792
Cheltenham
Thanks for these. Unfortunately there is no radio in a decodable format inside these transport streams that I can find.
EnoSat
enosat.euweb.cz
Slovakia
NIT_Table
12507.57 H SR-500
        Table_ID: 62 (0x3e)  [= DSM-CC - private data section  // DVB datagram]
        section_syntax_indicator: 1 (0x01)
        private_indicator: 0 (0x00)
        reserved_1: 3 (0x03)
        Section_length: 84 (0x0054)
        MACaddrbyte/DevicdID 6: 61 (0x3d)
        MACaddrbyte/DeviceID 5: 12 (0x0c)
        reserved_2: 3 (0x03)
        payload_scrambling_control: 0 (0x00)  [= unscrambled]
        address_scrambling_control: 0 (0x00)  [= unscrambled]
        LLC_SNAP_flag: 0 (0x00)
        current_next_indicator: 1 (0x01)  [= valid now]
        Section_number: 0 (0x00)
        Last_Section_number: 0 (0x00)
        MACaddrbyte/DeviceID 4: 1 (0x01)
        MACaddrbyte/DeviceID 3: 172 (0xac)
        MACaddrbyte/DeviceID 2: 8 (0x08)
        MACaddrbyte/DeviceID 1: 0 (0x00) => MAC-Address/DeviceID: 00:08:ac:01:0c:3d
        IP_datagram_bytes:
            Version: 4 (0x04)
            IP header length: 5 (0x05)
            Type of service: 0 (0x00)
            Total length: 71 (0x0047)
            Identification: 14272 (0x37c0)
            Reserved: 0 (0x00)
            DF: 0 (0x00)
            MF: 0 (0x00)
            Fragment offset: 0 (0x0000)
            Time to live: 4 (0x04)
            Protocol: 6 (0x06)  [= TCP]
            Header checksum: 3227 (0x0c9b)
            Source address: ac170e01 [= 172.23.14.1]
            Destination address: ac010c3d [= 172.1.12.61]
            TCP_data:
               Data
                    0000:  0c 3d 0b 00 0f 02 ab 07  8a 05 59 00 d0 0b 11 04   .=........Y.....
                    0010:  00 e5 c3 dc 51 43 3d 7a  a7 74 7a 7f f6 73 c5 2c   ....QC=z.tz..s.,
                    0020:  7a 42 43 07 8c de 3b 0c  2a 61 b0 d7 ea bc cc 6f   zBC...;.*a.....o
                    0030:  f2 d3 07                                           ...
        CRC: 2344052425 (0x8bb766c9)
NIT_Table
12509.14 H SR-550
        Section_length: 82 (0x0052)
        MACaddrbyte/DevicdID 6: 242 (0xf2)
        MACaddrbyte/DeviceID 5: 15 (0x0f)
        MACaddrbyte/DeviceID 1: 0 (0x00) => MAC-Address/DeviceID: 00:08:ac:01:0f:f2
        IP_datagram_bytes:
            Version: 4 (0x04)
            Total length: 69 (0x0045)
            Identification: 7157 (0x1bf5)
            Reserved: 0 (0x00)
            DF: 0 (0x00)
            MF: 0 (0x00)
            Header checksum: 9395 (0x24b3)
            Destination address: ac010ff2 [= 172.1.15.242]
            TCP_data:
               Data
                    0000:  0f f2 0b 00 0f 02 a9 07  71 00 d1 0b 11 04 00 6d   ........q......m
                    0010:  03 05 54 0a 19 d0 07 84  66 e6 2e d5 b4 28 eb 84   ..T.....f....(..
                    0020:  43 7a 75 fe 4d cc 68 f2  58 ed 2b 47 74 3e 4a 41   Czu.M.h.X.+Gt>JA
                    0030:  5b                                                 [
        CRC: 3105703975 (0xb91d4827)
stephan94
Bavaria
this is what I get with IQMonitor
EnoSat
enosat.euweb.cz
Slovakia
So your LO2 value should be 10600.41 MHz ;)
