7.3W multiple IP streams
Satfaca
Melmac (46N, 14.5E)
Melmac
I may have overseen this topic .. if so, admin please move this post elsewhere.
If not, I would like to get some guidance how to get these multiple IP streams running on E2.
What is the command to be put in Telnet in order to analyze the stream (something like wget 192.168.64.109:8001/dvb-ip-mpe2ts/1:0:C:C8:9C54:77EC7ABDC:0:0:0:/2002/224.30.2.122/6000 !?)?
I remember being able to watch the 21.6 IP streams before, I am struggling with 7.3W though.
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - TBS5922H - Octagon SF 8008
Lombardy - Italy
I usually record few megabytes of the PID and then i use dvb-ip-mpe2ts in scan mode
dvb-ip-mpe2ts -s 100 -i record.ts
Bye,
Satfaca
Melmac (46N, 14.5E)
Melmac
Unfortunately I do not know how/what that means ... I am not comp savvy. I've only learned some procedures with Octagon (thanks to you).
cirio70
Lombardy - Italy
Easy way:
record with a pc card a few megabytes of the stream.
rename this record "record.ts"
FTP to your octagon in the /tmp folder
now enter with telnet, move to the /tmp folder and use the command i wrote above
you should see a list of the channels present in the stream jus like this:
root@sf8008:/tmp# dvb-ip-mpe2ts -s 100 -i 224.ts
Nr. | PID  | Dest-IP-Address | Port  | Payload Type     | Channel Name
1   | 1011 | 224.100.100.5   | 5000  | 33  MP2T       AV | Channel List
2   | 1012 | 224.30.3.11     | 6000  | 33  MP2T       AV | orp01-ten999-ch002-hls_sb
3   | 1012 | 224.30.3.10     | 6000  | 33  MP2T       AV | orp01-ten999-ch001-hls_sb
4   | 1013 | 224.30.3.12     | 6000  | 33  MP2T       AV | orp01-ten999-ch003-hls_sb
5   | 1013 | 224.30.3.13     | 6000  | 33  MP2T       AV | orp01-ten999-ch004-hls_sb
6   | 1014 | 224.30.3.15     | 6000  | 33  MP2T       AV | orp01-ten999-ch006-hls_sb
7   | 1014 | 224.30.3.14     | 6000  | 33  MP2T       AV | (null)
8   | 1015 | 224.30.3.16     | 6000  | 33  MP2T       AV | orp01-ten999-ch007-hls_sb
9   | 1016 | 224.31.3.10     | 6020  | 33  MP2T       AV |
10  | 1016 | 224.31.3.10     | 6000  | 33  MP2T       AV | orp01-ten999-ch001-dash_sb
Bye,
Satfaca
Melmac (46N, 14.5E)
Melmac
Is there a way/command to analyze "on the go" ... directly from the stream receiving from the receiver?
I mean like the DAB streams... with wget something...?
Satfaca
Melmac (46N, 14.5E)
Melmac
What should be done in lamedb?
I normally change things here:
Normally there's something to be added or changed in the " Extra parameters".
EnoSat
enosat.euweb.cz
Slovakia
yes, added DATA pid - c:15xxxx
EnoSat
enosat.euweb.cz
Slovakia
Satfaca
Melmac (46N, 14.5E)
Melmac
No, unfortunately still not.
Satfaca
Melmac (46N, 14.5E)
Melmac
Thanks to another friendly assistance from the forum colleague :-respektwe managed to find the bug in the system which is now up & running.
So here are now all 25 streams/channels running on E2. The quality is rather poor but ... who cares.:)
jsda30
edision os mio 4k
spain
really great work
jsda30
edision os mio 4k
spain
its possible to get the stuff from you? thanks in advanced
Satfaca
Melmac (46N, 14.5E)
Melmac
I don't know what you mean by stuff; there are many things to have on the receiver in order to get these various streams running.
For me in the beginning all this was a complete dark but thanks to a couple of threads on this forum I slowly started to learn what is "chinese" and what is "japanese".
I suggest you to study these threads in particular:
RAI DAB+ feed from 5 West
Arqiva National DAB Feeds on 4.8E
13.0E IP multiple IP streams
21.6E IP multiple IP streams
First you need to have essential files (ETI tools) installed in the receiver and then you need to learn what's needed to be entered/adjusted in lamedb (either directly or through DreamBoxEdit - easiest and clearest for me) to bring certain channels to "life".
It only makes sense to one to learn how to handle all this to have real fun. It seems impossible in the beginning but after a lot of trying progress comes along for sure.
There are users here who know incredible things (at least in my eyes) and are always ready to explain/help with Q&A.:Y
jsda30
edision os mio 4k
spain
thanks for your fast replay...
yes i have eti-tools files and some radio chaneels dab feed..
i was talking about your lamebd file....
ill check the threads...
Satfaca
Melmac (46N, 14.5E)
Melmac
OK, so if you've already successed with the DAB streams, it is time to deal with the IP streams which are not that different to deal with.
Maybe best to try the polish radios on 7E or spanish/portuguese on 30W first.
IP TV channels are then almost the same ... if "I don't know what" is correct in the receiver's software. Important are dvb-ip-mpe2ts & dvb-ip-mpe2ts.pl files. If those are present and still no channel working, than you potentially have the same problem I had which I cannot even explain as I don't understand anything of it.
