7020 noob problems
drats
VU+Duo, Vu+Duo2, Vu+Zero, Gibi 1.5m, TBS 6903 PCI
North West UK
Hi, Just got my box this morning after doing some homework on it so was feeling confident, but ive hit a few probs i was hoping someone can help me with:
I have installed Gemini 4.30 image and rather than load a channel list i prefared to do my own scan of sats and channels But 1W is not on the list! Am i missing summat?
Also i went to blue panel to instal Camd and ccamd so did that, then installed config for them both but couldnt find k**Ys for any of them in Addons or AES for them as i understoodyou have togo into user script to run online updater?
I hope ive made myself a little clear :confused
Sorry i posted in wrong section my brain is overheating!
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
Have You checked 1W ? so U know that U have a lock on it ?
drats
North West UK
i forgot to mention i am using USALS as i am familiar with it but 1W is not on the sat list for me to scan in,
drats
North West UK
Now after lots of re-flashing/booting 1W has suddenly appeared on my list so the easy bit is sorted.
Put simply i am now struggling with which emu to install? EMU config? Does it need keys? And where they are installed?
I see lots of ppl saying in var/bin lol but i see lots of those folders.
Flashing image - no probs
connecting to net - no probs
ftp - no probs
Sorry for all the questions but
If someone can help i would be eternally grateful as i am feeling rather tense lol
HB13DISH
Retired Mod
Middle East - Israel
ftp - no probs
If you can connect the box to the internet, then use the blue button and Addons which will take you to the Gemini site
Install emus and plugins.
Tip:Use a flash USB, otherwise you will run into memory shortage soon.
drats
North West UK
Thanks for that, i have eventually got up and running...well crawling really. 9 hours later lol.
Is there a easy way of knowing which emu is suitable for which package and what is available?
hope that made sense.
HB13DISH
Retired Mod
Also install Mgcamd 1.30
drats
North West UK
