Wanted 720k 3.5" Floppy Drive
davemurgtroyd
Oxford
Oxford
As per title I am looking for a 3.5" 720k floppy drive for a PC. I have numerous 1.44Mb dives but DD discs formatted at 720k in them are very unreliable when using them in a very old 8086 PC with built in 720k drive.
stonesatellite
Vu+ Duo 4K SE (2x DVB-S2X) (2x Xbox One USB tuners (1x DVB-C & 1x DVB-T2) (1x Nooelec NESDR Nano 2+ USB RTL-SDR tuner)
Octagon SF8008 (2x DVB-S2X)
Mut@nt HD51 (2x 2x DVB-S2X)
Triax TD110
Sky zone 1 minidish
Inverto Black Ultra Twin LNB
Alsat Superior Dark Motor
Onkyo TX-SR605
6x Bose Acoustimass/Lifestyle double speakers
Stone, Staffordshire
davemurgtroyd
Oxford
Oxford
Many thanks for the offer but if it has a card reader then it is 1.44MB. I have dozens of 1.44 MB floppy drives but the problem I have is that although 1.44MB drives will write 720k discs reading them in a 720k drive is very hit and miss (probably down to double width read heads compared to 1.44MB drives.
Terryl
Custom built PC
I have several from old PC's that I have recycled that you can have,(I would have to check to see if they are 720 or 1.44) but the postage $$ from the US to you may kill the project.
davemurgtroyd
Oxford
Oxford
Thanks for the offer but unless those PCs were early 486s or older then it is unlikely that any of the drives are 720k.
However I think I may have another solution - 8086 is a Sinclair PC200 and has external plugin floppies - a 3.5 and a 5.25 - and I have found a working tower PC (486) with I believe a working internal 5.25 drive. So I now merely have to find my 5.25 floppy discs.
The PC200 is a very unusual PC built in case like an Amiga (see attached video) and Binary Dinosaurs - Sinclair PC200.
It has CGA monitor and RF UHF output to connect to a TV, standard RS232 and Centronic outputs. The two internal 8 bit ISA expansion slots (NOT 3 as stated in video) are accessed via a hinged flap on top of PC. I have a couple of 8087 co-processors to fit.
Resurrecting this PC may well surpass Vipersan's retro resurrection :D
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I wonder if any of the ancient IBM POS systems we have in work that we binned today have one, these are ancient.
Will check tomorrow if I remember. (I work for a company that services POS equipment)
I think they might be Model 4683 or similar, I know they are very old.
