75E ABS2
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
First transmissions from ABS2?
3964V is 15.0dB now, could this be ABS 2?
This txp should be easy, even in the south of England on this strength.
Retired human
Only a tip of south eastern England can 'see' the satellite at about 0.8 degrees above horizon!
margusten
Lat 59.40 Lon 24.68
DR.HD F15, TBS-5925, Dream 800PVR, GM TripleX
Aerial AS24 polarmount 95E - 13E Ku+C, fixed 3M 28.2E, 27.5W ...
Estonia
I have this news of ABS-2
My scan is little bit old - about 2 weeks.
But My goal is Motorvision HD 3679 V 29000 5/6
margusten
Lat 59.40 Lon 24.68
Estonia
I have more news that other channels changing to ABS2 on 29 March 00 Malaysia time.
Today I made new scan of 75E C-band.
No lock on Motorvision HD today.
margusten
Lat 59.40 Lon 24.68
Estonia
Now most transponders are moved to ABS2.
Finally catched one, signal here is much weaker than ABS1 C band was.
margusten
Lat 59.40 Lon 24.68
Estonia
I can see MotorvisionHD is moved to ABS2.
8PSK changed to QPSK.
This helps alot to receive a weak signal.
aceb
Prof Tuner 7301 /
Sussex
Same situation on Ku in the UK, much weaker than ABS-1 and so far no locks on anything from ABS-2.
Retired human
You need to try a 1.2m, Paul :)
aceb
Prof Tuner 7301 /
Sussex
I keep telling him he needs a 1.8 up there and I'd be happy to install it but for some boring reason he's not interested.
Lasseparabol
3 m Prodelin
Echostar AD-3000IP
Dr.HD F15
Sweden south part
This new ABS2 is not as strong old ABS1
3680H 27500SR Somsat TV, BON and a test card.
3752H 2400SR Indenpent TV
Kveys
Southern Finland
Sorry Lase, these both are from 76.5E. Only frequencies so far from 75E are here 3545H Al Hurra, 3556H Pinoy and 3617V Motorvision HD. Last one strongest and yes ABS1 was much more powerfull and no Cambodia anymore.
