gandalfthegrey
Specialised Contributor
- Aug 29, 2004
- Age
- 63
Dreambox 800HD (clone)
Gibertini 85cm dish
4 way Diseqc switch........
linksys access point connected to Dreambox..
- dublin,ireland
Hi guys....My brother in law just moved house and is installing his TV in the same location that the previous owner had his sited, This poses a problem as his surround sound system is installed across the room where the wiring for same was already installed leaving no connection between TV and Video player,there is however a 9 pin female lead at the TV running inside the plasterboard up the wall and through the ceiling and down to where the surround sound is..problem is both the TV and DVD player have standard S video connections..is there any way to make use of this 9 pin cable, because as it stands his TV can't connect to the DVD otherwise..I have searched for a 9 pin to scart adapter but have had no luck, does this exist? any help as usual is much appreciated..
cheers
gandalf
cheers
gandalf
