TDnTDE
- Jul 16, 2009
- Age
- 33
Sky Minidish
Sky+
26" Wide Belinea LCD
- South East England
Guys, Hi...
I have a feeling this post may be a little long...
Basically I have a Terrestrial Roofmounted Aerial that's now over 25 years old, supplied with old coxial coming down into the house (which is unaccessible without doing quite a bit of work)
Over the past few years I've gone through around 5/6 Digital TV Cards, ranging from freecom, leadtek, hauppage etc..
I run a few freeview boxes off this aerial which all work fine, recieve up to around 75 channels (radio included) All being ran off of an old (very old) signal booster in the loft.
Out of all the TV Card's I've tried, all have suffered from sound & frame lag, resulting in me only being able to happily view a maximum of 10 channels. System Specification each time has more than been up to the task, so I know it's not a system / card related issue.
I was going over a few scenarios today of maybe replacing the aerial, cabling, adding a new aerial. Come to the conclusion that this'll either be too costly or will fail due to the placement that I'll have to have my new aerial at, gone through it in detail looking at the transmitter maps and other houses aerial directions, it'll basically have to sit on the front of the house looking towards the coast, away from the vast majority of signal in the area, Bluebell Hill / Crystal Palace, totally pointless!
As a last measure a few months ago I also tried running new cable straight down from the booster, still nothing. I know that my signal level (strength?) is high, so the quality may be lacking due to the old aerial? I have no idea and want to move away from this means of recieving TV.
______________________________________________________________________________________________________________________________________________________________________________
Read on from here if you just want my questions. O-zzz
I've had Sky TV for a few years, No problems what'so-ever.
Here's a image of my current signal into my Sky+ box
_http://img114.imageshack.us/i/35308175.jpg/
Bare in mind when that shot was taken there was rain, thunder, and lighting outside, I still had perfect picture on the TV however. Rarely get any interference from the weather on my pictures.
In my new approach to get TV>PC Viewing working I've decided to go satellite. Had a look today, I have a minidish and have run down the cable from the dish into my room to the computer.
Now I just need a new Card.
I also have a few questions i'll frow in...
Is my signal any good? (during the weather I had)
Are any HD channels avaliable to FTA Satellite
EPG Guide's, is there any way to get these for FTA Satellite?
What Satellite Card would you recommend?
Can you access Interactive with recommended card?
I'm from Essex, which Sattelite would be best to try to stream from, I'll probably get asked it in setup, I'll have no idea?
I've been looking at these cards so far. My budget is around £80
Terratec Cinergy S2 PCI HD
Hauppauge WinTV Nova-S USB2 Satellite Reciever DVB-S
Thoughts?
Sorry for the HUGE post!
Thoughts?
