a problem in searching for new channels
takyeldin
150cm dish LNB, nokia 9665 receiver.sftware 1.43CI_E,hardware version 2.0
Egypt
i have a problem in searching for new channels :confused.
when starting searching, new channels appear in the search page but when i start to save these channels it says that there is no enough memory to save.
i tried to delete some channels "many channels" to be accurate but a i had the same problem.
i have a nokia receiver (piece of shit).
i need a good solution for my problem​
if i need to reinstall the RX software tell me how plz!??​
satelliteman
Try re-booting receiver and then removing a group of channels to give you space to save new channels
takyeldin
Egypt
re-boot from receiver settings !?
satelliteman
Unplug power and reboot. Try then to remove channels :D
takyeldin
Egypt
the same problem
takyeldin
Egypt
i reinstall the rx and search again.
while searching the same message appear that the memory storage is not enough (the message appear after approx. 300 channel search)
takyeldin
Egypt
My nokia is 9665
software version 1.43CI_E
