golpesar
- Dec 30, 2007
- Age
- 54
- Relook, AMD
- Iraq
I have an IPBox 250 CubeCafe. I have installed Nabilo V08 For IPBox 250 Final 2 version into my Flash. Everything is Ok. Great Image with a lot of works. Thanks to its developers.
I have installed several images using Sif Team Flash Wizard Pro 6.3 and they are working properly. Thanks to Sif Team for their greate work.
I have a problem with this version. I want to use http protocol via Internet Explorer to install an image to HDD. As you know, I can type the IP of IPBox in the browser and goto Config Menu. When I choose "Boot Manager" it identifies flash wizard. Now I click "Add" in order to add another image. A popup window appeares and tell me that there is no image in "/var/mnt/usb"!!!
as You know Cube Cafe 250PVR does not support usb and I am going to install the image to HDD. There is no option to change the above mentioned path to something like this "/var/hdd" because all installed images are stored in the "/var/hdd/fwpro".
Whould you please tell me where I can change the above path to what I need?
Regards
Regards
