a strange problem !!
Rollen
Satellite
Syria
Hello guys :)
I have a strange problem with my starcom SR-X3100CU ultra .. since it was working very well with the latest software,
Today I restart my receiver as usual to let it upgrade itself .. but when the ( upgrade data ) sign apeared on the screen it took longer than usual and then the receiver restarted and the sign apeared again and that seem to be repeated for ever !!!
I couldn't find out what happened !! or how to solve this problem !!
Any one can help me ?
Thank you very much in advance
Regards
rollen
HB13DISH
Retired Mod
Middle East - Israel
Rollen said:
Hello guys :)
Regards
rollen
Try shutting down the box and then pull the power cord out.
Wait 10 minutes, plug the power cord in, switch on the receiver and report back if this helped or not.
Rollen
Satellite
Syria
Thank you very much HB13DISH for your reply,
I tried it but it didn't help :(
I still have the same problem !!
I can use my receiver as mauch as I want .. but as soon as I turn it off and then on to let it upgrade itself on hotbird .. the problem comes again ..
any other solutions ?
Rollen
Satellite
Syria
Still waiting for any help or advise ..
Thank you
I think that only someone with the same model of receiver will probably be able to help, or perhaps the person from whom you bought it.
Is this update to do with card sharing over the internet?
Rollen
Satellite
Syria
Hello rolfw,
nope not really .. this update is for TPS .. if you turn the receiver off and then on only on hotbird the receiver give you the sign that the data is upgrading and then you can watch all TPS channels ,
Unless you upgrade the data by turning the receiver off and on you can't watch the TPS,
the same sw was working for over than 2 months .. and I can't explain why this problem apeared now !!
do you have any advice for me ?
thank you rolfw for trying to help me .. I really appriciated :)
Take care
HB13DISH
Retired Mod
It is probably the software that is causing it.
Either look for a newer version and update or if there is no update, just reinstall the same version again.
You are probably aware that TPS will be gone gradually in few weeks, starting with all the MVs on 31st May.
Good luck. :)
Rollen
Satellite
Syria
Thanks again HB13DISH,
I couldn't find any newer SW .. and I tried to reinstall the same version more than one time but it didn't work :(
seem to be no way to solve it !!
yeah .. I read about this few weeks ago but I didn't know for sure when that will be :)
I read also that they will be moving from hotbird to Astra .. true ?
Thank you again HB13DISH and good luck for you too :)
