wilmslow00 said:
PLEASE I NEED LINKS FOR UPDATING THE RECEIVER TECHNOCOMS X-650 ,,KEYS,,LOADER... AND ALL INFORMATIONS. THANKS.
Dear
This is the last Patchg for your technocomes X-650 dated 28/3/2005 open alls
X-650 Software
http://www.technofw.com/x-650PLUS5.zip
http://www.technofw.com/ARIONER.zip (Loader)
How to you the loader :
0-CONNECT THE RECEIVER TO THE COMPUTER THROUGH RS-232C CABLE(CHECK IT ON WEBSITE)
1-OPEN ARIONER
2-PRESS ON OPEN
3-SELECT FILES *.AUC OR *.BUC DEPENDING ON THE SOFTWARE USED.
4-PRESS SEND PROGRAM TO IRD
5-TURN ON YOUR RECEIVER
6-DONT TURN OFF THE RECEIVER UNTIL IT GIVE YOU 'SUCCESSFULLY END"OR YOU WILL DAMAGE THE FLASH MEMORY(WHICH IS OUT OF GURANTEE).
http://www.technofw.com/HISPA.zip (For the keys)
How to you use the programe
1-OPEN GASOLINE
2-PRESS ON FILE THEN OPEN
3-AND CHANGE TYPE FILE TO *.KEY
4-SELECT SOFTCAM.KEY
5-TURN ON THE RECEIVER
6-ON STANDBY MODE PRESS BY REMOTE CONTROL 246807-PRESS THE RED ARROW TO SEND THE FILE.
if you need anything more plz send me and you will be welcome
