abs-8776 reciever
secure
humax,pi300
Australia
does anybody know of anything that can be done with thw abs-8776 reciever it seem to be locked to austar. anything to unlock it and view other channels.
many thanks
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Welcome to the forum secure
have a look here and see if you can identifiy a similar looking model, that may then help you to track down some software
secure
humax,pi300
Australia
thanks i will have a look
boxnut
turnkey 700mhz athelon .5gb ram,120 gb,drive
j-test j-tag setup
I just started testing oe of these[mine has all chinese lang in menu]
seems to be similar to a 2 tsop 301 with a 5500 decoder
has a 8952 cotroler so should be piece of cake
let u know what i come up with
boxut
boxnut
j-test j-tag setup
:-sball don't know where my prev reply went but??
Ok this might help get you started..the 8776 is jtagable,via 'cn16'. pinout is " 1,3,5,7,9,11 are ground,
pin 2 is trst,pin 6 is tdo, pin 8 is tdi, pin 10 is tck, and pin 12 is tms. the boot select is a headder just behind
the screw at the center of the board . jumping an inner pin to the pin closest to r106 will boot from the dcu.
the pin at the other end of the headder is 'esel'. there is a master reset 'button' located rear of the system
cpu (sw6).
this ird is a 2 tsop unit so i'm guessing that it is similar to a 301-13. if you are using jkeys you may have to use the
version for the 301 .
in either case, you would have to edit 'jkeys.def ' file to specify 39vf160 (check this) flash chips,and 24c64 eeprom.
I havn't tried new bins yet so don't know what works. this ird may be more like a 2700,4900,drd420
my unit is cofigured for 'jedi'tvb ( asian) but does have some 'fta' features. don't know if the aussi system
has any fta features.
i will see if i can add some pix to help(abs8776.zip)
hope this is useful to you (or anyone) boxnut
humax2001
dm7000
amd64
aust
hello
is there any uses for these box's now ?
mikehunt2008
nothing special
Australia
Does anyone have any info on the recovery menu password for this decoder?
Hillsbysa
Dreambox DM800
Autralia
Hi, saw this somewhere...
abs-8776 secret menu
turn the box off at the power point & back on.
when the green lettering " DIGITAL SATELLITE RECEIVER LOADER v3"
appears immediately press down,up the timing on this is important it only works when nothing but
" DIGITAL SATELLITE RECEIVER LOADER v3" is displayed.
The word "UP" will appear in blue lettering at bottom left hand corner if you did it correctly
now press OK,then UP,UP,DOWN.
This will take you to the RECOVERY MENU.
