adding spotify connect to rune - raspberry pi
Archive-8
i wanted to add spotify connect to rune,
log in to your pi via Putty
username: root
password: rune
paste: fdisk /dev/mmcblk0
then press D, select 2,
Press "n" to make a new partition, then press E.
Press "t" and enter the value "83" to mark it as a Linux partition.
Press "w" to write changes and exit. You may have to reboot after this for changes to be registered. This has resized the partition, but not yet the filesystem.
Next, use the resize2fs command in this way:
resize2fs /dev/mmcblk0p2
and once complete reboot once again.
to load Spotify:
using putty add this
wget https://github.com/Fornoth/spotify-connect-web/releases/download/0.0.3-alpha/spotify-connect-web.sh
chmod u+x spotify-connect-web.sh
./spotify-connect-web.sh install
Next install the spotify key with the following command:
wget -P ~/spotify-connect-web-chroot/usr/src/app https://github.com/balbuze/volumio-...onnect/spotify-connect-web/spotify_appkey.key
Your Spotify Server should work. Test it by typing:
./spotify-connect-web.sh -o hw:0 --username [12345678] --password [xyz123] --bitrate 320 --name [any name]
ctrl c to close the server down.
still with putty
Type the following:
sudo nano scs.service
and paste the information bellow
[Unit]
Description=Spotify Connect
After=network-online.target
[Service]
Type=idle
User=root
ExecStart=/root/spotify-connect-web.sh -o hw:0 --username [12345678] --password [xyz123] --bitrate 320 --name [any name]
Restart=always
RestartSec=10
StartLimitInterval=30
StartLimitBurst=20
[Install]
WantedBy=multi-user.target
Close the editor and save by typing ctrl-X
select Y to save
Type the following:
sudo mv ./scs.service /etc/systemd/system/scs.service
sudo chmod a+u /etc/systemd/system/scs.service
sudo systemctl daemon-reload
sudo systemctl enable scs.service
sudo systemctl start scs.service
and finally
sudo reboot
and enjoy.
