Advice about twin satellite outlet socket
Oldsberg
Basic
Finland
Hello!
I'm searching after a twin satellite f outlet socket and I know Triax have had these before. But do they still have them for sale?
The thing is that I only want 2x satellite outputs and no radio or TV outputs on socket.
They tend to go by the name "Wall Plate", and I think you''ll find several manufacturers will do them in twin format.
I recommend you select ones that maintain screening throughout, as cheaper ones can be easy targets for local interference from eg DECT phones.
Edit: Googling "Satellite wall plate twin" does indeed bring up lots of hits. Adding the qualifier "Triax" brings success, too.
Oldsberg
Basic
Finland
Thanks for leading me into the right path!
satelliteman
Try Triax modular snap in outlets.
TRIAX 304201 Grid White x 1
TRIAX 304254-WH Grid Single F x 2
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
S'funny, I had trouble finding decent twin satellite wall plates too, I ended up using the Triax modular range as well, no problem, very easy.
Those Triax modular sockets look very similar to the Legrand ones I used wiring the house in France. This name might be easier to find in Europe.
