Advice of Funcard 5 Please
New2It
Dreambox 7020, HH120 Discq notor with Triax 1.1m
I have a Funcard 5 and a programmer but do not know what to do.
What type of files should I be looking for?
Does the card (when programmed) go into a card slot by itself or have to go into a cam (currently matrix reloaded)?
How do I tell if it's working if it is in the cam as the cam decodes as well.
Please help as I am drowning ....
RyokoFanUK
I believe if you have the latest version of matrix reloaded you dont need any funcard at all.
As for programming the funcard I suggest you look for the 6x1 files, the will containg the loader + hex files you need to program your funcard - these 6x1 files can be found in my sites, however, like I said, if you the latest version of MR I dont think you require this.
Also, if you do not have the latest version of matrix reloaded (MR) then you could even use your funcard to upgrade the CAM to the latest version... but thats another story all together.
New2It
Dear RyokoFanUk
Thanks for the reply.
Do you have time to tell the other story on how to upgrade the CAM or know of any links that I can follow
Many thanks in advance.
Digital2
Dreambox 500s,Dreambox 800HD PVR,Max 1000,Vivax 505, Starsat 200CI. Desktop with WinXP, Laptop with Vista & Netbook with Win7. External HD/Media Recorder.Hotbird,Nilesat,Asiasat3S & Intelsat.
Middle East (Currently!)
I want to 'assemble/ make' a card programmer (whatever its called!) I got my hands on a slot from an unserviceable receiver and need the CIRCUIT DIAGRAM for it. I intend to re-programme FUN CARDS with it.
Any links here on this site please?
Thanx
RyokoFanUK
www.funcard.net
That have their own diagram + software to build your own simple programmer - in the early days I built it and worked well :D However its very simple, the programmer will only program funcards 1-6 and nothing else.
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
My local computer shop has started selling Fun Card generation 5 (£5).
I take it these are used for Cable?
Can they be used for anything else?
Good for CAM loading as well, but otherwise no.
