Advice Please
radtv
Supporting Advertiser
Can you tell me where I can find a step by step guide in programming cards with my infinity/Phoenix programmer.
I have a gold card, several fun cards and a TiT card.
I get really confused and would welcome any adviced.
Regards all
Jessjosh
rob43
canaries
hi jessjosh. have a look in the tutorial & how to guides in the forum jump below. or try dugwati which you should find in nobblys links section. i´ve just programmed my 1st tit card and it was´nt as bad as i thought it would be. rob43
radtv
Thanks for that I have printed off the How to.....
When I insert card the message comes up 'unsupported titanium OS found'
I have tried to reset the card but all that happens is a message comes up 'sending trapcode' and stays like this for 20mins until I quit!
Please help
Regards
guiri
Manchester, UK
It can depend on what software you are using.
I had the same problem with the normal titanium programming software, then I tried the programmer bundled with the TMB (the mighty bosom) code, and it worked for me first time.
Other people suggest doing ctrl-alt-del, or opening another application (eg. browser) whilst the trap code is being sent. It it very timing dependent.
Regards
radtv
Thanks for the advice, where can I find the mighty bosom programme?
Regards
guiri
Manchester, UK
T24 posted this last week:
http://www.satellites.co.uk/php-bin/forum/showpost.php?p=51424&postcount=1
In general, when looking for files, start in the forum here:
http://www.satellites.co.uk/php-bin/forum/forumdisplay.php?f=44
If you get no joy, try some of the sites in:
http://www.satellites.co.uk/php-bin/forum/forumdisplay.php?f=40
Finally (and with square eyes), if you can't find what you are after, pop back here and ask :) .
Also a very common problem with first time Titanium programming is to do with the FIFO buffering on the serial port, particularly with Windows XP.
If you are running XP, go into Device manager, Com ports, advanced and turn off FIFO buffering.
