Advice with my dual receiver setup
KBMC-001
Fortec Star 4200 & Fortec Star Passion +
Aberdeen
Up till now we have had only a Fortec Star 4200 with a USALS mount. I have a 90cm dish.
The wife decided she also wanted to be able to watch Russian TV in the bedroom upstairs so I got a Passion + HD receiver (works great and quality is good). Now as I inherited a Sky aerial and cable setup when I bought the house, the main cable from the dish enters in the living room downstairs. There is a second cable that runs from downstairs to the bedroom above. So I have used the loop through option on the Fortec 4200 to feed the Passion + upstairs.
Now generally no problems both receivers can operate the USALs mount however My Passion + set upstairs after I have done a scan of the Astra satellites doesn't pick up so many channels as the 4200 does downstairs. For example
Foretc 4200 picks up all the FreeSat channels ITV2, ITV2+1, ITV3 etc. The Passion + of the extra ITV Channels it only picks up ITV2+1 and ITV4+1
Now is this due to signal attenuation in the loop through cable?
Another thing is I did get ITV HD and BBC HD channel show up in the channel lists but I think this was before I upgraded to the latest Firmware.
If anyone can help me out that would be great. I'm also wondering if my dish has been slightly pushed out of alignment due to high winds we get sometimes. I have noticed during high winds that satellite TV is almost unwatchable on most channels which I put down to dish movement.
Check the LNB settings in the Passion. Universal or Universal 1 or Universal 9750/10600 (Whatever the Passion calls it!).
Also, check your Transponder lists are up to date - either correlate them with _http://www.flysat.com/28east.php or carry out a Blind/Auto/Network scan if the Passion has that facility.
BUT, most importantly, don't forget that when using IF Loop-Through, only one Receiver can win control over the LNB: So put the lower priority one into standby, or they'll both try to switch Polarity and Band and will generally be in conflict.
KBMC-001
Aberdeen
Thanks for that. I will try what you have suggested.
Also didn't know about the LNB thing and 2 receivers. However what if both receivers are set to the same satellite eg Astra 2A etc?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
As mentioned it is because of the loopthrough. The polarity of the lnb that is controlled by the first receiver dictates that the 2nd stb will only be able to watch channels on that polarity, thus limiting your viewing choices on the 2nd stb, unless the 1st stb is put in standby then the 2nd stb has control
The dish can only point at one satellite at any one time therefore you can only receive channels on both stb's from the same satellite at the same time. What I suspect you are experiencing is the re-use of frequencies across the arc which makes it look like you are receiving from two different satellites at the same time
