Al Jazeera sport 13E
ciaran
Is there any way of getting this channel open at the minute?
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
yes paying for a card
ciaran said:
You should do stand up.
Stand Up is humour: The answer given, however, was correct.
Most (But not all) Encryptions are now so secure that you have no option but to Subscribe, as advised.
ciaran
Can you see the difference between your response and his?
pipino
Back from the dead
just wonder now how shall i take this comment now :cool: ,
by the way the yearly sub is very cheap so hacking it as i understand you want to do is not worth it
pipino
Back from the dead
??????????? at least i spend some minutes of my life to tell you whats needed to see those channels
ciaran
Now, that's much less terse.
I understand what youre saying - but I needed it for tonight (therefore the subs not an option) and just wondered if any Cams opened it, as I havent used them in a while..
thanks.
dodgy internet it is then.
bigtee
Sky; Raven 90 multi-LNB 1W,5E, 7E, 9E, 13E 16E, 19E, 28E; 60cm Triax dish on Moteck SG2100 motor; Various Receivers
Kent, UK
Some keys are posted on some forums occasionally but I don't know if they work or last for long!
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The JSC+1 +2 etc channels seem to be viewable on Nilesat at the moment, without a card. Might be temporary FTA, not sure.
