Aligning terrestrial aerial with Revez STC60
Dasilva81
Motorised setup (dark motor) 42e - 30w
London
Hi good afternoon,
I have a question about aligning an aerial i have purchased.
I have bought a vision log36 aerial for my installation which was recommended for my location.
just wanted to know when using this meter what channels should i be looking at for alignment, my meter has an lcd screen which shows me various channels to choose from, it also shows signal strength and signal quality.
Which transmitter are you likely to be using ? There are three based on your location of London.
Dasilva81
London
I will be using crystal palace.
I live in Wembley area so I think crystal palace is the strongest transmitter for that area
You can see Crystal Palace from much of Wembley. You should not need a meter for alignment unless you are North west of the stadium.
If you are then channels 21 to 35 contain everything you need for searching, channel 22 if I recall is the most critical.
Dasilva81
London
Thank you very much for help.
My postcode is nw10 2uu
I think I should be ok.
Who recommended the aerial and with how much information?
