llss
- Oct 9, 2005
- Age
- 53
- technomate 1500 ci super 80 c m dish diseque 1.2 superjack motorised system dragon celebro cas 3
- northumberland
whist installing new digi aerial and 4 way line power control mast head amp the other day , i occured a massive over load on anolouge channel 5 . it was annoying at first , but customer wanted freeview allover the house as priority , for which i alligined with good passes on every multiplex, in the end i had to reduce antuunuate aerial by 15 db to better the anlouge channel 5 , the mast head amp was just a variouble gain , its getting quite tricky now to ballance anolouge signals and digital , as i rather use distribution amps rather than stack aerials , mind you i have never occured this problem before , i think i am going to move away from the labgear amps ,to powerfull , anyone came across this problem lately
