Amstrad DRX400 problem
tiko789
Amstrad DRX400
Hi all, new here, be gentle with me:confused
I have been given an Amstrad DRX400 which has been unused for some time. When I connect it to a (definately) working connection it comes up with a message "no satellite signal is being recieved". Im told this might be an easily fixable problem & NOT a fault...Any ideas? Thanx
tiko789
Amstrad DRX400
Hi rolfw, I have a Panasonic receiver working on the connection at the moment. When I swap receivers (yes Im turning box off at the mains before disconnect/connect) & connect the Amstrad thats when I get the message "No Satellite signal"
satelliteman
Yes, you may have a fault with the power supply that causes the no sat signal message or could be a connection fault as described.
DishDick
Gran Canaria
Typical causes of this fault are - failure of one or more capacitors in the PSU or faulty tuner unit ( often caused by people doing up the f connector too tight and snapping the inner core in the tuner unit (as connector on box turns round).
gunn1e
Sky-HD
S.E. United Kingdom
The DRX400 are famous for this fault, rare to find a working one these days.
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
What if its on very old software? Have you tried upgrading it ?
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Very unlikely but.........
Check that that the default freq has not been changed. Seen it a few times where people change it when trying to add channels.
Press
Services
4
01 Select
2
Should be default to 11778. Use the red button to reset defaults and save.
