Anixe HD and Astra HD at 19.2E
icarusi
Fortecstar Passion+
Can anyone here receiving these channels get the P or P+ to show these channels from standby. The only way I can get them to show correctly is to go via an SD channel. Still sometimes getting lockups requiring a hard start, if I use the channel up/down buttons or list selection rather than the numberpad. Ditto with HD channels on 28.2 shortly after switch-on.
howardbowell
Dreambox 7000
HP Laptop
Yes, have found exactly the same problem.
Have you edited the channel list via computer? I have and believe this to be the problem.
If you do a factory re set and use the standard settings every HD channel will work. Very strange!
icarusi
Fortecstar Passion+
No, just the standard scan from the P+.
I wonder if the preset pids or symbol rates are a bit off, or something? I'll have a double check with Lyngsat. Radio on 28.2 is similarly iffy from startup. I need to go to TV and back or from standby to get a signal.
OTOH my LNB may be slightly off frequency which wouldn't help matters.
howardbowell
Dreambox 7000
HP Laptop
Use channel editor version 1.01, and problem is solved. Try it!
Also upgrade pox to the latest firmware, available from the fortec website.
