Okay , but 1 of the members poste though is another calculator I can rememberHere is the formula........
Formula:
λ = C/f
Where,
λ (Lambda) = Wavelength in meters
c = Speed of Light (299,792,458 m/s)
f = Frequency
Or the calculator web site....https://www.everythingrf.com/rf-calculators/frequency-to-wavelength
So do you know what channel you want to listen to?
If not and you want to cover the whole FM band then you start at 98 MHz as the FM band covers 20 MHz, (88 to 108 MHz)
So for a full wavelength antenna for that frequency it would have to be 3.059 meters long.
I want to build a Yagi antennaFor that band all you do is to take the upper frequency (230 MHz) and deduct the lower frequency (174 MHz) this gives you 56, divide that by 2 for 28, add that to the lower frequency for a center band frequency of 202 MHz, that would give you a full wavelength of 1.484 meters.
You can make a simple "T" antenna using TV twin lea
