Any 'How to' s out there ?
neil8888
Visit site
Are there any How to's out there to show how to program say a fun card with an elvis programer ?
cheers
Neil.
Hi Neil, I thought that there was, but must have been imagining it. :)
First thing you need to do is download TJ's Multiprog, have a look in the downloads section.
When you have this, you will need to download the relevant fun file from somewhere like Phill's or Toes.
Unpack the zip file to a folder or desktop and then open Multiprog, you will need to go to the MP set tag and press power on.
Insert the card, contact face down.
Then go to the Fun/Atmega tab and either select the right card type or use the identify button.
Most of the files will only have to hex files, one for Flash and one for external Eeprom, select the right ones using the load button and browse to the previously unpacked files.
Hit the program button and you are away. :)
TVDX
bitent.cjb.net
neil8888 said:
many thanks mate,
Can i just ask?,
where is this program TJ?,
i cant find it by name.
Will this program work for any programmer?.
And also where are Phills and Toes?.
And is Viaccess hacked at all?.
TVDX said:
Can i just ask?,
TJ's Multiprog is in the download section (see top left hand corner of this page) It is only for the Elvis
Links to Phill's and Toecutters are in Nobbly's Big Links Forum.
Viacces is hacked, Viaccess 2 is not.
