arion AF1500E.please can sombody help
davidbenizri
hello to all
hello.i do have arion AF1500E.please can sombody help me.to program it.kan iemand mij helpen met arion 1500e/a.u.b /model name;FANNAN/software version;$SPCA4148s150EC/boot version;0016.1/buyer version;polari$/ul type;GP1.3/S/w build date;jun 12.2004..please thank you david.you can e-mail to benizridavid@yahoo.com.
rockchang
dvb.nease.net
hp7800---perfect arion-1700 clone receiver! +
coolsat 4000pro +
pansat 2500a +
starsat sr-x200ci +
infinity usb+cas interface 2+matrix reloaded
china
davidbenizri said:
hello to all
it is easy to find boot version:10.1 or 11.1 upgrade files.
but not easy for 16.1 boot files!
are u familiar with jtag? i can provide u jtag software and original bin file.you can change the loader version back to 10.1 or 11.1 .
gasansat
SPC AF-1500 it's only for Israel in the world it's know as AF-1700
gasansat
davidbenizri
THANK YOU for your advice
gasansat
david check your p/m
i send you new s/w for 1500
regard
gasansat
she12126
Dear gasansat,
Could you please send me the new s/w for Arion 1500 via p/m? Thanks in advance!
Shaoyi
regard
gasansat
she12126
Dear rockchang,
Would you please send me the jtag software and original bin file via p/m? Thanks in advance!
she12126
noone_2004
ARION AF-1500E
Gasansat, Please send me software for 1500 and instruction for flashing .
email: wifi_guy@greenhillhortons.kicks-ass.net
she12126
to my Arion 1500e. I used Arioner2.4 for downloading "S170EC_$STK_A4870_20050226_AUCPC.auc" file, but I got "Download fail". The other file "S170EC_SPR_A2733_20040120_AUCPC.auc " downloads to IRD successfully with LANG on LCD but no pictures when connected to TV with correct connection. I do not know why. Please help. Thank you again!
she12126
dwarf said:
Hi Guys,
for the moment very good software for Arion1500/Arion1700 and clones is h**p://www.starsw.com/WorldinBoxII-26.02.zip or h**p://www.starsw.com/WorldinBoxI-26.02.zip .
For updating software - use newest AutoArioner.
Direct link: h**p://upload.dvhk.pl/content.php?id=10128
rockchang
dvb.nease.net
coolsat 4000pro +
pansat 2500a +
starsat sr-x200ci +
china
she12126 said:
Dear rockchang,
she12126
HERE IS THE JTAG SOFTWARE AND ORIGINAL BIN FILE:
AF1700-JTAG
Mahdi007
OpenBox
SKY+
Pioneer XED 50" Plasma
B&W Surround Speaker
DENON AV/DVD Player
Rel Quake Sub
Hi, can you also post a small instruction on how to flah the system and make the bootloader to 11.1?
AF1700-JTAG
dwarf
Arion
@she12126
1. Download fail = incorrect header. Use "AutoArioner", which will correct this problem.
2. LANG = no channel list, no language setting. Select your preferences, set up satellite data and scan channels, or, if U wish - send *.ird with ZodiacEdit v.5.04 tool. Observe correct Database version (check in Menu - Tools - Info), if necessary correct it with ZodiacEdit (save as, then select Database)
3. Check other scart outlet (in some softs it is changed).
Mahdi007
OpenBox
SKY+
DENON AV/DVD Player
Rel Quake Sub
Will this work with Bootloader 0016.1? as this is what I have, also I can currently get Multivision but can not ge an $ on ASTRA i.e. Taquila
Any advice?
Tanks
dwarf said:
@she12126
she12126
Dear dwarf,
Thanks a lot for your kind help. Could you please tell me where to get AutoArioner and ZodiacEdit v.5.04 tool?
she12126
dwarf said:
@she12126
she12126
Dear rockchang,
Thanks a lot for your quick help!
Also, I still can not get my Arion 1500E to work - I flashed it with all the s/w that was said for Arion 1500E or 1700E. But, I first got 8.8.8.8. then LANG then 0001 with no pictures on TV. It seems no connection but actually the IRD is connected correctly. Please use your expertise to help me. Thanks in advance!
she12126
AF1700-JTAG
