Arion Receiver software
imeddie69
Visit site
Hi All.
I hope someone can help me find S/W for My Arion AF-1900CI or wher i could
find some websites with Arion S/W
Did a quick search, but all I could find were resellers for the receiver in North America. It appears to be a relatively bew model, so software may not be available, may be worth E-mailing one of the resellers.
nutty boy
Hi
I have a software for arion af-1700e is it suitable for u if so tell me and i will sendit to u
Anjaansa
nutty boy said:
Hi
I have a star track world in box reciever which is similare to Arion AF-1700e, nutty boy can you please send me the software of Arion AF-1700e to my email address (Mailto:anjaansa@hotmail.com) if it is latest one. or advise the website which have latest software for Arion Af-1700e
rockchang
dvb.nease.net
hp7800---perfect arion-1700 clone receiver! +
coolsat 4000pro +
pansat 2500a +
starsat sr-x200ci +
infinity usb+cas interface 2+matrix reloaded
china
nutty boy said:
Hi
hi, are u in america?
can u use arion af-1700e to deal with some encrypted channels?
rockchang
dvb.nease.net
coolsat 4000pro +
pansat 2500a +
starsat sr-x200ci +
china
several days ago, i used arion af1700e software to update my startrack world in box receiver,
but failed.
i think the different boot version cause this failure.
rockchang
dvb.nease.net
coolsat 4000pro +
pansat 2500a +
starsat sr-x200ci +
china
i found arion website, but download only for buyers.
http://www.arion.co.kr
Anjaansa
rockhang! did you edit the header beforee uploading it to star track. cos i think we have to edit the header of Arion Af 1700E to Star track world in Box with the help of AUC_Hedit.
gavanm
doea someone have any idea where can i find arion 1900ci software.cause i flash it and now does not wake up at all.
please help!
PELEN
Arion Af 17000 E Emo Prorami Ariyorum Lütfen Yardimci Olursaniz Sevİnİrİm
pirayas
Dear Friend,
Pls help me..
How can I upgrade the software for my receiver..?
My receiver is STARTRACK world in box..
Pls get me master code of the receiver..
Rgrds,
Pirayas
pirayas4*hotmail.com
McDude
To upgrade your startrack get software from their website starsw.com. The file you download should have an explanation. Also use the SEARCH button at the top of this page and type in startrack...you'll be surprised how much info there is on this receiver
BERIBAK
Hi All.
ArionFan
Hi
Can somebody help me to find correct satellite receiver? I am searching something similar to polish Ferguson AF-3018SE (it is FTA Arion S170EC type). Tell me please where, in which shop can I find (I am from Belfast) this receiver? If is exist some board especially for Arion-type DVB Sat receivers, then please send me a address… Thank you
leo1352
after uploading keys to your star track ,go to antenna settings while highlighted type with remothe: 19380 and then 2486.
degryse
I look to update my Arion AF-1000SE
some firmware:
http://dvb-upload.com/index.php?dir=Inne%20tunery/ARION-FERGUSON
code & link:
www.arion.co.kr Arion AF-1000SE= Ferguson AF-1018SE!!!!! All the software are the same. Ferguson-Made in Poland, Arion-Made in Korea. THX the polish team! The koreans are very closed! They sell the softwares!!! SO, when u look for Arion ,look for the ferguson egal! It's better!!!!
arion 1700e=telstar 4018se=openbox 1700e
http://www.telstar.com.pl/telstar/index.php
index AF 1018SE http://dvb-upload.com/index.php?search=1018&date=0
The list of codes to activate hidden functions in Arion based receivers.
For f/w with EMU function to activate it:
1. Go to menu. By pressing menu on your remote
2. Key in : 19370
3. Key in pin: 2486
Now in menu – games, you shall see emu-keys section, should you wish to alter the keys manually, you need to enter pin 0000.
If you forgot the pin you had entered, press 0786 to reset it and enter menu or blocked channels.
Other Codes to be entered when tuner is in stand by mode.
42114802500 – Full information about your tuner (h/w & f/w)
24680 – Uploading keys (irk) or channels list to the receiver.
74621 – Downloading channels list from the receiver.
74623 – Downloading full set of keys from the receiver.
74620 – Downloading f/w from the receiver (AUC_HEDIT).
14802 – Downloading boot from the receiver (AUC_HEDIT)
14809 – Downloading full f/w with boot from the receiver (AUC_HEDIT) – you get “universal” f/w this way.
Test codes:
42125
42126
42127
__________________________________________________
To connect your PC to the receiver, you'll need null modem RS 232 9-pin cable:
1+6---->4
2------>3
3------>2
4---->1+6
5------>5
7------>8
8------>7
How to receive the STB Data from the STB to PC.
NOTE: Receive indicates that transfers the existing data (STB Data) from the STB to your PC; whereas, Send indicates that transfers the added or modified data from PC to the ST:cool:.
1. Choose the "Receive" menu from Main Menu or Toolbar.
2. Turn on the main power of STB.
3. Press special key-code "74621" in the STB stanby mode.
4. The STB Data will be transferred automatically, with a window indicating the process status. (If you wish to abort receiving process click 'CANCEL' button.)
5. When finished the receiving process, click the 'OK' button and then an active window will appear your received data. Please save the data with specific name using "Save As" menu.
How to send the STB Data from PC to STB.
1. Choose the "Send" menu from Main Menu or Toolbar.
2. Turn on(reboot) the main power of STB.
3. The STB Data will be transferred automatically, with a window indicating the process status.
If you wish to abort sending process click 'CANCEL' button.
AF1018SE, AF2018SE, AF3018SE, AF4018SE AF5018CI s/w upgrade
Upgrade procedure
1. Power off receiver.
2. Connect PC and receiver using a serial cable.
Receiver should be power-off state.
3. Execute "ARIONER.EXE"
First, Select proper PORT. ex) COM1 or COM2
4. Click the "Open" button and select "ADA2030SE.auc".
Click the "Send program to IRD" button.
Then, typically "Last status" shows message of "Waiting connect request ack".
Now PC are ready to transfer.
5. Power on receiver
upgrade process will be automatically done in a few seconds.
You can see the progress with PC and/or receiver.
NOTE
When receiver shows "Saving" message, you have to be very careful.
Never power off during this save time. It couldn't reboot and
you have to send back the receiver to us.
At the end of the process, small message window at PC will appear.
Please don't care about the message.
Click "OK" button to clear the message.
Receiver reboot automatically. Check front display of receiver.
If it shows "----" or any channel number "xxxx", then successful
