Advice Needed assembling 2.4 fortec
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
just unpacked a 2.4, first problem instructions for assembly are non existent.
OF the 2 rings would the bigger be on the floor, or supporting the actual dish?
Their is a piece of paper with a diagram but is unreadable, and the screws and bolts don't seem to match what is suggested.
There are a couple of recent topics on the forum about this dish, both "aceb" and "s-band" installed this model for some tests. If you have a search for their topics there will probably be a lot of useful information about putting it together. They will probably pop into this topic shortly if they are browsing the forum.
Rgds
s-band
Essex
The large one is the ground part. As MB says, have a look at the existing threads. Here's the link to assembling mine The C-band Tin-Dish challenge
I've attached a good .pdf of the instructions which can be enlarged quite a lot.
  • 240cm.pdf
WHATAGOAL1
Leic
got it all setup today, just now need to add arms tomorow and lnb, and will compare with ny 1.8 cm firstly will compare 55w and58w thanks to s-band for his tin dish thread
Journey
drx 890
photos please or it never happened :-biglaugh
WHATAGOAL1
Leic
first blindscan
1.8cm 160 tv
2.4fortec 204 tv
55west
WHATAGOAL1
Leic
checked panels with a piece of string, strings were missing by more than i/2 inch, so realigned and and got
257 tv a vast improvement on the 1.8 channel master
so offers accepted for 1.8 cm with ground mount driven by 2 acuators!!!!!!!!
Retired human
I doubt Fortec Star will be any better in Ku band though. Unless Ku is not of interest.
