ASTON 1.03 & seca 2 titanium.....
sat_freak
With all this seca2 hoopla goin on, is there any hope for owners of Aston 1.03 CAM like myself? Would a titanium card be any good with that CAM? ANd which programmer is most suitable ( i.e. cheap) to do a titanium?
thank u v much guys....u rockkkk!!!
turny
msn.co.uk
tyne and wear
i believe aston 1.03 with blue titanium running os 1.03 will decode what you want as regards a programmer a cheap pheonix serial 3.5mhz will do i use a old clanzers build 5 from the old on digi days
use titaniumosupdater2 to downgrade os
now use prog1.9
erase
load files
burn
good luck
sat_freak
thanks a bunch...but i m a bit unsure about how certain u are. hav u actually seen it workin with an aston 1.03 or is it merely ur speculation?
the programmer that i currently use for my goldwafers .... wud that be jus sufficient? it doesnt hav any name its jus one of those generic ones....
also are we jus limited to sky italia 13E or can we venture elsewhere too..such as 19.2E french CanalSatellite and/or spanish Digital+ packages?
cheers
antenoref
...I have an older smartmaouse: with 2 jumpers 1 X 3,5/6Mhz and the other to invert/normal
Do you think guys I can use it with a titanium???
TNX in adv.!!
satfanuk
I have a humax 5400 with aston 103 with blue titanium card with 1.06 works fine
