Aston Simba 201 + WinLoader
markhunter99
Does anyone know anything about the windows version of 'Loader', the program some of you may have used to make your receivers do more things than it really should? Its called, imaginitively, Winloader, and I've just tried to use it for my Aston Simba 201 but, despite using the different flahing speeds (it allows you to alter them), all file trnasfers get to between 0-6% then freeze. Does anyone know enough about this program to advise me as to why this might be happening. The normal dos-based version didn't even begin to transfer files. It said it was going, but nothing was moving through.
Also, is there any way to find out how capable your receiver is just from its hardware/boot versions etc? I can get hold of the numbers, i just have nothing to relate them too.
Thanks,
Mark
Globo - Digital 400 s
Germany
Thanks,
Mark
SOMEONE HELP ME AND THIS MAN PLEASE??????
Also, where can i get the F***** program? im pissed of searching for it.
Not even on the undergrounds i could get it.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
What it wrong with you have you never heard of google :-doh!
No wonder you are frustrated click here
But it must go by another name as these programs do not have anything to do with loading software into an stb
The Winloader the OP was referring to is one designed specifically for a range of Aston receivers (Winloader 2.12 available from _www.funfiles.ws).
It's used in conjunction with a JTAG programmer, but I found it a bit clunky to use; far better is AstonFlash.
DON'T use with any other STB.
